Hey guys
Need some people with more experience than me about cars to give their opinion.
This issue is:
I got my car recently serviced during the week. The mechanic said everything was perfect see you in 3-6 months. Now over the following days a series of oil puddles popped up in my garage. I looked underneath my car and at the front of the car (between the battery and radiator) it was all shiny black and oil was dripping. Perfect, all mechanics are closed till the new year and I won't be able to drive my car. I then popped my bonnet to check the dip stick and suprise, suprise the dipstick was not in correctly. It was sticking out and on further inspcetion I could see oil on my z pip and down the side of the engine. It was disapointing because i take my car to a respected import mechanic in sydney and a little mistake like this has made my engine all dirty and my car unlikley driveable till I take my car back in the new year.
What I wanted to know from you guys if i should be able to drive my car. It would be extremley coincidentel if the leak is coming from some place else so i assmue that the dipstick not being in correctly is the source of the leak. I have attached two photo's below, one of the dipostick and a leak on the floor. The leak on the floor gathered after the car being parked in that spot for one hour.
In summary: Can i drive my car with the oil thats available in the engine or has the car dropped too much oil that it is not safe to drive. I have maybe drived between 100km-200km since the service and no warning lights have popped up on my dash.
https://www.sau.com.au/forums/topic/386559-need-your-opinion/
Jawrgy, you need to find out how much oil is in the engine; wipe the stick properly, and reinsert it. pull out and check.
If it's above the low mark, you're ok, but I'd still put some in. If it's just that drop on the end of the stick, add 1/2 a litre and see where you end up. If still nothing, add another 1/2. Take your time there's no reason to hurry. I'm assuming you've got some 10w/40 oil handy?
You'd be amazed how much oil you can pump out through a dipstick, but by the same token it's amazing how much of a mess you can make with 500mL of oil; once it's sprayed around.whistling.gif
They're a hard engine to check once they've been running, as they hold a lot of oil in the heads etc, and it takes a while to run back down. I always check mine first thing in the morning.
If you're not sure though, please don't drive it; better to wait a day, than destroy a perfectly good engine.
Good luck, Dale.
P.S. After the weekend I d be dropping back and telling him what happened, and getting him to dump the mixture of oils out, refill, and steam clean your engine bay. It's the least he can do.
Edited by Daleo
Mate, not all mechanics ate closed until next year.
I'm back at it on Wednesday.
As stated above, pull the dipstick, clean it with a rag, reinsert, pull once more and check level.
If on the dipstick, it is approximately 800ml from low to full.
If not, add 1l, and follow the check procedure again.
DON'T drive with low oil.
It is highly possible all the oil is from the dipstick.
Depending on engine wear(not knowing your car), its also possible the dipstick was blown out from blow by.
Happened to me at the drags once.
Was ok for the rest of the night.
Oil went everywhere.
Fill the oil, make sure the dipstick is all the way in, clean it down, and you should be ok.
If you still don't feel confident checking your level, ask a family member or neighbor.
Better to ask a stupid question or favour, than pay for an engine rebuild.
Good luck with it mate
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
