this is the one Sidd is talking about
was raining so a little rushed. but getting some reflections was nice.
would have liked a bit more light around the highlighted part, but also wanted to be home in a dry bed, haha
  • Replies 99
An RZ Supra I shot the other day. If anyone is in or near Canberra I'd love to do a shoot with you!
<br style="color: rgb(51, 51, 51); font-family: 'lucida grande', tahoma, verdana, arial, sans-serif; font-size: 11px; line-height: 14px; text-align: left; ">davidsupra2.jpg
<br style="color: rgb(51, 51, 51); font-family: 'lucida grande', tahoma, verdana, arial, sans-serif; font-size: 11px; line-height: 14px; text-align: left; ">davidsupra3.jpg
went for a job interview to enter the glamorous world of electricity meter readering yesterday. not sure how i went as they didnt call back as promised, but found an awesome warehouse after it was over which made the day worthwhile...
and some more stuff...
/spam
lol
Edited by Jay019
Indeed awesome spot jay. Go back for sure. Would love to see more from there.
Matt - nicely done. Whats on the top left of the image? Looks like a reflection? Or sun rays?
Make up artist pulled out so we had to do what we could:
Edited by siddr20
/spam
lol
Imagine the potential of this place in NSW!
where is that warehouse jay?
somewhere in adelaide. random find while riding my bike.
anyway.
had a go at a light painted join up. this piece is around 30 meters long. took over 2 hours just in shooting, lol. i know i can do better next time, was still pretty cool doing this much tho.
(click click)
Edited by Jay019
