Morning guys,
One of the first tech post's ive done asking for help (As most end up in some retarded flame war)
I've recently completed a RB25det swap into a S13 silvia. Turned over first go, idle's well, after sorting out radiator issues, runs well now.
Major issue is this, I take it for a drive around the block, boost's well, runs very good, once it warms up, turns into a horrible ride. Idle is extremely rough, to the point of nearly stalling, needing to feather the throttle to keep her alive.
Not 100% sure what's going on, I've checked temp sensor connections etc, thinking it was stuffed when going from cold to hot, this was fine, replaced the fuel lines all the way into the back and fuel filter, thinking this might help, swapped to new spark plugs, still doing the same thing.
Not really sure what's going on, have checked a few forums and havent been able to find a definitive answer so helping someone here has some knowledge and may be able to help me.
Some forums mentions the CAS and timing (Which i'm not sure if this could be the issue?)
The CAS was removed when the engine was out, as I replaced the belts for higher RPM rated ones etc.
Any help would be greatly appreciated, cheers!
https://www.sau.com.au/forums/topic/387084-rb25-det-engine-issues/
Can u try another afm
I can try another AFM, thankfully my daily is a R33 GTS-T with no issues, I can always unscrew this one and swap it to test?
What ECU?
Standard R33 GTS-T Computer - Nothing aftermarket at all.
New oil, new filter, new fuel lines, new filter, new headgasket, new plugs, new belts etc etc. Only aftermarket addons are a FMIC, BOV and a POD filter, nothing else at all. I do however... Have no exhaust atm, but I couldn't see that being the issue?
Clean the idle air control valve. Take it off the back of the plenum, clean it out with solvent (carby cleaner is good). Do the TB as well (just spray it in there and wipe out with a clean rag).
What I suspect is happening is that when it's cold the auxiliary air valve (which is thermostatically controlled) is letting in air to keep you idling smoothly, but once you get the coolant warm that shuts and you rely on the idle valve. Which if it is dirty (or given that this is a conversion, not wired up properly) makes it run just like you describe.
PM sent so I don't look like a tool. I will try both of these when I know more =P
Have u checked the timing when it starts playing up ?
I think it maybe CAS related or maybe even something like coils or ignitor
I have not checked the CAS yet, nor have I checked the timing when its playing up, as it wont idle with me out of the car. Resembles something of a massive lumpy cam lol. I'm still learning the in's and out's of the engine and slowly learning / trying to figure it out.
What sould I be checking with the CAS, adjusting timing etc? This engine used to run perfectly (Was removed and sat in a shed for 2 or so years) could the packs die over time from doing nothing? Not 100% sure why it would idle fine, then work fine under load, but not run properly when rough, thought the packs would die at higher rpm over being warm?
What could the ignitor be doing?
Edited by BukkaneNinja
Ill second it being the AAC valve being dirty or not even wired up.
If its fine under load when hot and doesnt miss fire, id say its safe to say its not the CAS, AFM, ignitor or coils, these all usually break down when hot and under load.
Check the plug on the AAC valve with the ignition on, yoi should have 12v on one pin. The 0V pin is controlled by the ecu when the engines running. This can be checked with a 12v led to see if its pulsing.
I'll check this wiring tonight. Hopefully can find some answers
Also check your ecu temp sender, on front of inlet manifold into water jacket, if its busted/missing/covered in sealant, could be still telling ecu to run on cold start (tune) but maybe not...
Checked all these plugs, wiring is fine, I also got a small file in and hit the terminals to make sure contact was made firmly.
This ^^^^^^ was my next port of call hahaha
But as posted above CAS Afm coils and ignitor can breakdown from heat
U can test the CAS by pulling it out leaving it plugged in and turning it by hand .
U will here the injectors pulsing and be able to see coils sparking also
But after re reading the first post ( I tend to skim a lil hahaha) I would start with the iac valve an then go from there
There could still be a dud coolant temp sensor there it may just not do what it's suppose to be doing . If u have a spare swap it just to be safe and rule it out
Might have too, will do the AAC and IAC first, then that will be my next port of call I guess.
Hey guys,
Quick update, followed a how too guide on here, guestimated where the idle screw was and refitted after cleaning the whole thing down (gasket stayed intact).
Ive since taken it for a few laps around the block, the issue seems to be gone. Only time will tell however, after I get an exhaust and get it out for a few track days.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
