righto got a r32 gtr now wanting to swap it over to e85 whats needed besides the obvious stuff like bigger injectors and fuel rail. what size injectors are people runnin 1600? do ya have to change all the fuel lines? and what sort of pump and surge tanks are people running? some photos would be great aswell thanks
https://www.sau.com.au/forums/topic/387201-e85-whats-needed/
-5s two off and probably only hill climb dont need to worry about a drum of it, its now on pump 1600 injectors and currently have a nismo intank pump. could i get away with that or do i need to setup a surge tank setup and pumps. so the standard fuel lines are fine. power goal as much as it can get hahaha with the -5s
-5's.
Well I am running 70% duty on ID 2000's (which are 2225 cc). *quick calc* = 1557cc worth of injector. Thats for 420 rwkw. Daniel has made 400 rwkw on ID 1000's. Different tuners, different dynos. No idea.
See how you go with your current setup.
Is it a built engine?
lol...
But ye... The setup you have should be fine. It's "in the middle" of other setups (where some are 1000cc & some are 2000cc). Stock rail is also fine.
Fuel pump - arguable. Seems fine for some, not for others, depends on the tuner - go with what you have and see really.
If your going E85, i might have to as well, can't have you with more power than me @ HH :turned:
Just a tip; the search button is in the top right hand side of your screen. Or on mobile version, down the bottom.
Every aspect of this conversion has been covered with results by various members who have done it previously.
I'd suggest spending the time and doing the research.
ripps, we have very similar setups (as do most of the people posting these questions) built 26, -5's (i'm running 2530's).
I just have an intank Nismo and ID1000's. That's it. Obviously there's nothing wrong with going a surge tank, dual pumps etc either, just depends on the setup
and r31nismoid i do believe you already have more power than me!
:unsure:
Noooo... I'm only on 350 ATM due to exhaust, surely you'd have more than me!
Ash... E85? No way! I'll believe it when I see it :thumbsup:
Well if the competition is doing it, you gotta change with the times.
Thinking a flex type setup actually. Lotta cash though to do it over my current setup.
ECU + MAP sensor is $1750 + $650 for sensor, looms and display + tuning
Sell Dinosaur FC for $700 odd, Nismo AFM's $500 odd.
It's not THHHATTT bad. You being the 'response' phene you are should be all over it!
DO IT!
hey guys, dont wanna start a new thread so ill ask here, as most setups are different im after an answer for mine -
Its running 18-20 psi and making just 300rwkw. As i'd like to lower the boost a little to save the motor that little more i was thinkin of e85 what would i need?
main mods included -
550cc injectors - dont know a/f ratio
gt3071 - highflow
pon cams
higher flowing pump - not sure which one its walbro i think not that that helps :/
and using a NIStune
and all other mods to reach the 300kw mark
P.S how good would an adjustable exh. cam gear effect the power (with having anything to do with e85 but as it is now)?????
Thankyou to who answers :thanks:
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
