I have had to make the hard decision to sell my pride and joy. It is well known through both the skyline and general sydney based JDM community and has been owned by a true skyline enthusiast!
i could sit here and spill you some crap about how some grandma owned it and only drove it on weekends but lets be real, its a enthusiasts car who treats it like his first born, its serviced maticulously every 5,000km with spark plug changes every 10,000 and has had nothing but the best installed.
ENGINE:
- Full 100,000km service done at 99,800km (with gates racing timing belt, all pulleys, water pump and power steering pump replaced, full compression test)
- Apexi SAFC2 - tune done by indy @ IS Motorsports pulling a modest 200kw - improving fuel to 550km/65L
- HKS SSQV Blow off valve
- Enclosed (Boxed) Pod Filter with cold air intake
- Brand new yellow jacket coil packs - less than 10,000km old
- Brand new Front Mount intercooler - less than 10,000km old
- Full HKS Silent Hi-Power Turboback exhaust
DRIVELINE:
- Exedy 5 puk brass button clutch (not for the feint hearted)
- Tien Super Drift Fully Adjustable (height/damper) Coilovers and Cspanners
WHEELS:
- 18" Rota P45R 9.5" Wheels - Powder Coated Orange
- Federal 595 Tyres
BRAKES:
- RDA Slotted Rotors - Less than 20,000km
- QFM Performance Brake Pads - Less than 20,000km
ELECTRONICS:
- Clarion DVD Head Unit
- Shadow Orange Boost (on a pillar using a greddy a pillar mount), Water Temperature, Oil Temperature, Voltage Gauges
- Digital LED Shift Light
- Apexi SAFC2
- HID Headlights
- Full bluetooth mobile phone integration
BODY:
- Nismo 400R style bar (original 400R indicators) - Stickerbombed
- Nismo 400R style side skirts
- Custom rear "skyline" boot garnish - red led lit
- Cusom Guard Rolling
- Headlights Cleaned - Professional sanding performed to remove ugly yellow stains most japanese imports suffer from
- Cusco side mount numberplate bracket
INTERIOR:
- Custom Vinyl/Leather Re-trim (seats, doors, pilars, gear/handbrake boot, center console)
- Greddy A-Piller gauge holder
- Original Skyline floormats
- Nismo Chrome Gearknob
This car has been my pride and joy for the past 2 years and i will miss all the thumbs ups and jaw dropping reactions by young and old :D car is rock solid, reliable and has never let me down, selling only to fund a first home purchase
Price: $13,500
https://www.sau.com.au/forums/topic/387568-white-r33-bo05tn-skyline/
  • 1 month later...
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
