30k so it should've been immaculate
Yes I agree, for the asking price of $30K, this car should be mint and is far from it, rust, previous body repairs, gearbox issue, oil leaks, interior wear etc, etc. Is that 57K km mileage genuine? Also noticed that report said that it was a personal import and not a normal RAWS import.
Appreciate you posting this up for others. Was the Stateroads inspection done on a hoist and do you mind me asking what is cost for the comprehensive inspection?
Mileage is very unlikely, especially with those compression figures and overall condition.
I wasn't there for the inspection but in one of the photos it looks like its on a hoist.
Comprehensive inspection and compression test(extra) was $378. Well worth it especially when it saves me a trip from Brisbane to Sydney.
Some 260 RS
http://www.trademe.co.nz/Browse/Listing.aspx?id=437033811
and this one ...not a real 260 but has the R34 front and a built engine - just needs a Link and some better turbos:
http://www.trademe.co.nz/Browse/Listing.aspx?id=437749983
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
