Hey everyone, just a quick question or two about external oil pumps for RB's running a steel sump.
I've tried searching for info about this and havn't come up with a definite conclusion.
What i'm wanting to do is fit an external oil pump to my 25 NEO along with a high volume sump.
Question is, where is the best place for the scavenge side of the pump?
Would it be adequate to remove the welsh plug on the left hand side of the factory oil, put in an AN fitting and use this as the pickup point. Or would the small size of the oil gallery be too restrictive for the external oil pump. The external oil pumps i have seen, have had a -12 fitting which is quite large. This option would be by far the easiest i believe. Mainly for the fact that if i bought an ASR sump i wouldn't have to modify it and put in a new pick up point.
Or is it more advisable to have a new fitting on the side of the sump and use this as the pick up point. Obviously and inline strainer is required. With regards to putting in a new fitting, how is it done, is the pick up just a pipe that runs into the centre of the sump with a strainer attached, or is it done vertically?
Thanks, Daniel
Thanks, Daniel
Got to ask why? I see in your signiture that its a track car but I would seriously think about just using a good quality internal pump with maybe a larger sump volume. Most external setups only introduce less redundancy for no real gain in horsepower. There are plenty of track rb's running internal pumps with no issues.
This would require a collar to be fitted to the crank to run a good quality pump. I just sold my Tomei pump so i can go external.
I am in no way going external oil pump for power gains. Only for reliability, thats it. They are much more reliable than any internal pump. Of course you have fittings that can leak and there is the possibility of the belt failing which i have not heard of. I will be fitting an aluminium bash plate to prevent sticks and stones flicking up into to the pump/belt area.
An external oil pump with an accusump, a high volume sump is a bullet proof oil setup. I'm also doing this external oil pump, so that when my RB26 is built, i simply remove it from the NEO and put it onto my RB26, of course with a new sump to suit.
bigmikespec - Would you just modify the factory pickup and weld on a 90 bend and point it straight out the side of the pan?
Really I've heard of plenty of belt failures/belts walking off - but I've been in the industry for a while. If you must do it I would look closely at an EVOX sump. They integrate an external like pump into the sump.
Dont forget that your most likely going to run into oil control issues as well with the extra flow - all managable if you know what your doing.
Dont tell me youve seen belts throw off lol.
EVOX sump, hmm never heard of it? Any details on it? Links?
Yes, oil control is my main concern with this engine aswell as my RB26. I'm pulling the head off, throwing restrictors in, most likely i'll drill out all of the oil drains.
I'll be putting 1 or 2 -12 fittings on the RH side of the sump that will run to the top of the catch can to vent crankcase pressure. Obviously good head venting will be done. I'm trying to do every oil control mod i can think of without going overboard and overboard on spending.
The NEO comes with an N1 oil pump factory, Sure if i'm careful and avoid rev limiter and i put on a good harmonic balancer i shouldn't run into issues. But there is just that chance the gears could crack. (Waits for Ash to come on here and rant on about how good factory oil pumps are lol).
I might be telling porkies - it was the golf engine that integrated the oil pump into the sump. You maybe able to run a sprocket of the crank straight into the sump if you remove the oil pump would have to make covers though.
Yeah nah not doing that lol. Means having to pull the crank out and fit a collar.
I'm more or less looking for a bolt on kit.
External oil pumps are pretty cheap to set up nowadays.
I've done heaps of these setups.
They can and do throw belts it's not all that uncommon. Make sure you have proper hob switch protection to shut the engine down.
When we do Sumps for them they have a pickup that follows the perimeter of the Sumps bowl section floor. 3/4 diameter with holes bored in the bottom to draw through, end is blocked off. There is also additional baffling Around the pick up tube. The outlet comes out at the base of the sump with a -12an fitting.
External setups require a far larger oil supply than the factory pick up can supply, you need to know the flow rates of the pump you have to design a pick up arrangement to suit it.
You'll need more than the ordinary oil control modifications with some external pumps as well.
I think you need to sit down and actually work out what your doing with it rather than trying to throw a restrictor and pick up at it.
That won't work.
That won't work.
So how commonly do belts actually come off?
The pump im looking at using is an aviaid, it flows 16 gallons per minute which is 62 Litres/min roughly. At what RPM i can't remember.
So the sumps you build have a specially designed baffle, with the pickup on the bottom of the sump? How do you go about this with clearance issues?
By more than the ordinary oil control, what do you mean?
Cheers.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
