Sau Nsw Wisemans Ferry Social Cruise Sunday 19Th Feb 2012
Was there a photo of me getting on the ferry? The Sil80 had a HARD time getting off :|
-Alex
I couldn't take any photos because I was either too busy talking, handing out maps, or turning up late everywhere on the day!
But that's what a couple of us were worried about, we saw a few cars about our ride height make it ON the ferry ok, but had no idea what it would be like on the other side. Would've had to catch the ferry back to the south side again and then reverse off it!
  • Replies 181
My boat goes everywhere, no point in owning a car that cannot be driven I say, I always say that "low is slow" unless you have spent big dollars on correcting steering geometry, might need to change that to "low is no go" :whistling:
I think it depended on which ferry you caught over, I'll admit my car wasn't the lowest but it managed to get on the ferry fine and get off even easier - on the other side the ferry I was on they managed to make it so it was no worse then going over a lil speed hump to get off.
Still had a great run around the river back down old northern rd through the gorge and up the freeway to mangrove to catch up with the rest of the crew, made good time and wasn't dependent on ride height :P
-Alex
Yeah mate, I got one of yours getting on. I think I was a micro-second too late though as the shutter closed right when your front right wheel hit the bump/ramp. I will put it up for you tonight if I can.
PS - On a an unrelated topic - does anyone know when your warn status goes back down? Mine hasnt moved in years and I am itching to swear and be humourously abusive again.
Edited by Jez13
No worries, cheers matey.
-Alex
Doof, many a words have been exchanged over the forum and I didn't say hi, lol. What a snob haha. I only assumed you where there because msdoof was there but had nfi which guy you were.
Um doof was not there...
Sorry for the delayed photos guys,miss placed my camera.
Matt, thanks for the great drive mate.If it means missing the boat for a drive like that im happy to do that
all the time.
Great to meet you all.
all the time.
Did you make it to a fuel station??
Car sounds awesome going past on full noise, caught me quite quickly :worship:
all the time.
Nice collection of photos Michael. Yeah it was a good improvised detour :cheers:
Just made it .I must have been driving on fumes.It doesnt take long for that tank to empty when youre on boost.
Thanks for that mate.Its the best i ve had it running so far.Not bad for 16 psi. I cant wait to tune it at 26 psi and see the figures on the dyno.thumbsup.gif
Your R33 looks and goes fantastic,are you going to the Powercruise this weekend?
Thanks for that mate.Its the best i ve had it running so far.Not bad for 16 psi. I cant wait to tune it at 26 psi and see the figures on the dyno.:thumbsup:
Hahaha yea i bet it wouldnt take too long!!
That still makes my head spin only 16psi, its going to be an animal on 26psi!!!!
Thanks mate and like you cant wait to get some more boost through it :thumbsup:
Im working this weekend and somehow every yr i am on powercruise ill have to remember to take some time off next yr hahaha
Will be hitting the drags tho tomorrow if anyone is interested with my tuner and if the weather holds out
Nice one , let us know what time you do down the 1/4.I hope the weather holds out for you.
Hey Guys, I've been wanting to get on here and post pics of the event but I have been bent over with work. There is no point posting my pics on here as each photo is 16MB, so I loaded the maximum 300MB in one go onto Flickr. I have heaps more so will load more up as soon as I get more space to play with. Link is Below - Enjoy.
http://www.flickr.co...s/77653397@N06/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
