I have had some 300km/hr dial faces printed to suit the S1` Stagea (and could probably be adapted to suit R33 Skylines as the hole for the odo is not cut out when you get it).
To make it read correctly you will need a Jaycar speedo corrector kit (requires assembly and soldering at what they call "simple" level). I will also send instructions for wiring to your cluster (courtesy of an Aussie poster) and enclose an isolating washer that is required. I have bought a few Jaycar kits as they can be hard to source so all up with the dial face, Jaycar kit, washer and instructions its AU$99 posted anywhere in Australia.
If you want just the 300km/hr dial face its $30 including postage.
  • 1 month later...
  • 2 months later...
Hi Will the facing fit an A31 Cefiro se-4, The cef speedo looks very similar, What is the facing size so i can check, Thanks Jamind
Edited by jamind
  • 1 month later...
