  • Replies 285
well i pick up my GTR cams today and will install them on my day off this monday, will book some dyno time hopefully on wed and then post the results for everyone!
Sydney kid: would you recomend spending a few more $$ and going some adj cam gears? is it worth it or should i just throw the std cam gears onto the GTR camshafts??
Well bbenny, since you have to remove the std ones anyway, it is time efficient. You will get a better result, more in average power than max.
Bottom line is, it's your money.
Awesome, will be great to see the results
Mine arne't to far away hopefully, I am doing exhaust manifold, injectors and new ecu at the same time, so I have a bit more saving to do! :D
Sydneykid - quick question,
I want to reposition my throttle body at the front of my plenum, what are your thoughts on this? I am not doing it to see any power gain, just to get rid of some inlet piping and make it easier to adjust cams gears etc
Chris
Hi Chris, I don't like it, wouldn't do it to my car, not worth the effort. Do a search, I have written pages on why.
Cheers Sydneykid,
I searched long and hard, and have read pretty well everything I can
So is it worth using a 120degree bend, or jusy keeping it all stock?
Sorry all about the change of topic, but its all relevent to our mods and something I was considering
Regards, Chris
Cheers Sydneykid,
Regards, Chris
HiChris, the 120 degree bend design saves over 1 metre in pipe, which is 3 litres less air. So definitely worth doing in my opinion.
Well i picked up my GTR cams and they are in unbeleivable condition (thanks T88 on board) they have only done 30,000kms and look fantastic.
Re: adj cam gears
Yeah its defenantly a convenient time to change, but also adds another $399 to this mod.
if its only going to add maybe 5rwkw i wont bother but if it makes substantial gaines i will do it while its all apart. comsidering i just clicked over 100K kms the other day i will be fitting a new belt, and am now considering adj cam gears.
do you think it would be worth while sydney kid or just put that $399 towards suspension tweaks for the quarter?
thanks.
I have a 120 degree bend setup, and took a bit of work to get clear the oil filler cap, PCV valve and hoses and still be a nice and tight fit, but can be done. I would definitely recommend spending a Saturday cutting and trial fitting to get a good result, then throwing a case of beer at somons to weld up for you, nice tight fit and as others have stated cuts down a few litres of internal volume...
...the race is on to see who gets dons first...is anybody doing a before/ after run...im working on a guy to tune/clean up the maps with std cams, then GTR cams and cam gears to get a feel for the difference, as my before power figure is with a faulty AFM and A/F in the 9s and 10s...so the improvement from the tune alone should be pretty dramatic.
As for tough idles, try mega rich with fouled plugs, talk about lumpy idle (Go the Japs with their crazy rich A/Fs)
cool, i might look at doing the bend rather than cut and shut the plenum
Picked up my exhaust manifold today (cheers drifta32) so one more piece to the puzzle waiting to be put in place
Can't wait to get it all underway now!!
Chris
so what do all you guys think of adj cam gears? is it worth the extra expense? what are your experiences
You know you want to do it all at once, you just want us to give you an excuse. OK here goes......
Correcting/optimising the camshaft timing will improve the average power (10 maybe 15 rwkw) so that it doesn't drop off boost on gearchanges = faster and nicer car to drive. Better throttle response and, as a bonus, maybe 10 rwkw max power increase.
I have done one car, not ours, that made 18 rwkw more max power and 25 rwkw more average from 5,500 to 8,500 rpm after fitting the adj pulleys. But it took a fair retune to get it there, ignition and fuel where all over the place (perfect before cams and pulleys). It also had a big Turbonetics turbo on it, so it had the airflow capacity.
Better balance the books here, we also put and adj exhaust camshaft pulley on an R34 GTT expecting to get more out of the cams (not GTR). Best position was zero, so we took it off and sold it. A $50 (and 1 hours work) experiment well spent I'd say.
If they don't do anything, they are easy to sell.
How was that, convinced?
haha you should work in retail sydney kid, you know too well what i want to hear :)
any particular base setting you found worked well on the RB20?
i might give it a try and see how it goes, the only thing is ill be doing it all at once, so i wont know whether it was better than the std cam gear or not.
well i will let you all know how it goes hopefully by tuesday.
Hi, it's the usual RB settings, +2 on the inlet and -4 on the exhaust. Ours didn't like that much on the exhaust, we ended up around -3.
Sure you can, just do one power run with both cams at zero.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
