Hey Guys, I have decided i have way too much stuff in my garage and have come to the conclusion and that I'm not going to use a lot of this stuff and am just hoarding. Please pm me and I will give out my phone number for serious enquiries. I'm located in Victoria Point QLD. I'd like to sell the long motor first before the ancillaries, because if I cant sell it and use it, I'll need to buy all these parts (or equivalents) back.
Item:
I have an Rb25/30 long motor that i bought about 2 years ago as a long motor. I never saw the engine run, though I did talk to the owner at great length about it, he had reciepts from GT AUTO, showed me a dyno printout of it when it was tuned and i watched the oil get drained from the sump and had a good sort through it looking for grit and metal before i bought it. Its been on a stand the whole time and I have kept the sump full of oil and filled the bores with oil, removed the cam covers and oiled the cams before removing the plugs and turning it over by hand (usually done once a month).
By looking down the plug hole, the pistons look to have very little carbon buildup. I was told the bottom end was sourced from a low km R31 and had the bearings, piston rings, water pump, oil pump and gaskets replaced. The head is also standard with the external oil line plumbed in. I have removed the thermostat and the water pump has no corrosion and looks quite new. I'm not sure on the km's on the motor since it was built but it was in the car for 12 months before it was parted out.
You are more than welcome to do any inspection you like, but I am not offering a warranty. I'm not really fussed if it doesnt sell as I'd like to use it one day. I just cant see that day being any time soon.
Item Condition: good
Reason for Selling: Don't have a car to put it in
Price and Payment Conditions: $1000
Extra Info: It has r31 red top cam covers. long motor only, no manifolds or wiring. has knock sensors
Pictures:
Item:
RB25 genuine Greddy plenum with Q45 throttle body
Item Condition: Perfect. I bought this and nismo injectors from a guy who used them on a fresh built rb25. Car spent 5 hours on the dyno and developed a knock. He got the shits and parted out the car. It is basically brand new
Reason for Selling: not going to use
Price and Payment Conditions: $950
Extra Info: Will come with custom throttle cable to suit R33 (should work with other nissans too). It has also been powder coated black which is why it has no greddy sticker.
Pictures:
Item: 6BOOST exhaust manifold RB25. Top mount T4 Flange Split pulse
Item Condition: Perfect, never been used. Flanges have a little surface rust but i can sand blast if needed
Price and Payment Conditions: $1050
Extra Info:
Pictures:
Item: Turbonetics T66 Turbo and 44mm turbonetics wastegate
Item Condition: Fantastic. been used for less than 4 months
Price and Payment Conditions: $1100
Extra Info: I bought the turbo off a guy I work with. He bought the turbo brand new for his vl about 5 years ago and had it installed. He ran the car on stock boost for 4 months and he said it scared the shit out of him so he converted it back to stock, sold the car and bought a 4x4. He wrapped it up and put it in the shed and forgot about it. The turbo is externally gated and has a T4 flange. I'm not sure on the specs but it has a .86 rear housing so it shouldn't be a lag monster on a 6cyl. I forgot to take a pic of the wastegate (looks like a wastegate).
Pictures:
Item: Rb25 Gearbox
Item Condition: Good I think. I bought it second hand, was already removed from car. Shifter shifts through gears fine.
Price and Payment Conditions: $1300
Extra Info: comes with crossmember
Pictures: looks like a gearbox. can get pics if you really want some
Item: Nismo 740cc Injectors suit Rb25
Item Condition: great. Used for 5 hours on dyno since new then placed back in box. This was 12 months ago so id recommend getting them cleaned incase some dust has gotten in.
Price and Payment Conditions: $750
Extra Info:
Pictures: forgot to take pics, can take some if wanted
Item: OS Giken Twin plate clutch for RWD RB
Item Condition: great. Rebuilt by NPC and driven for about 2000kms
Price and Payment Conditions: $900
Extra Info: comes with new throw out bearing
Pictures:
Item: R32 GTST bonnet
Item Condition: good, no damage but has two holes for pins
Reason for Selling: sold my skyline
Extra Info:
Pictures:
Item: GREDDY Intercooler
Item Condition: ok, has some bent fins and some dings but doesnt leak
Reason for Selling: not being used
Extra Info:
Pictures:
Item: Sard BOV
Item Condition: good, works fine
Price and Payment Conditions: $65
Extra Info: 108_0548.jpg
Pictures:
Item:RB20 Starter motor
Price and Payment Conditions: $45
Extra Info:
Pictures: 108_0546.jpg
Item: R32 3" exhaust
Item Condition: not too bad. Its mild steel and a bit rusty but no damage
Extra Info: Goes from stock dump to tip. No cat
Pictures:
Item: R33 alloy radiator
Item Condition: Good, couple of bent fins but nothing major
Price and Payment Conditions: $180
Extra Info:
Pictures: 108_0573.jpg
Item: Stock Rb20 turbo
Item Condition: good, worked fine when removed
Extra Info:
Pictures: 108_0583.jpg
I have lots more stuff but I'll add to the thread a bit later.
Please pm me or post here If you have any questions.
Thanks
Zac
Edited by gibbau
https://www.sau.com.au/forums/topic/388671-rb2530-25-gbox-t66-turbo-6bost/
I also have an Rb30 crank I forgot I had.
Basically the story on this is as follows.
I work in a machine shop which has an engine reconditioning section. Someone came in and got a fair bit of work done to the crank and then bailed when he got the bill. It sat at work for about 12 months before it was offered to me to recoup some of the losses.
Work done to it is as follows;
- Crack detected (all clear)
- Had the oil pump drive welded up and the slots re machined to cover the whole drive ( much better way than using a crank collar). Welding introduces stress to the crank so it was outsourced and stress relieved.
- I did a small knife edging job on it. I didn't want to remove too much weight, just a bit less and also to help it cut through the oil a bit easier. I also polished the casting marks from the counter weights.
- The journals are grub screwed
- The rear main seal was repaired by myself back to original (if you ever see an rb crank, they are all worn in the seal areas)
Depending on what the power output of the motor will be will determine whether the bearings will require grinding (bigger power= looser tolerances). It was a while ago that i measured, but i blieve they were about 0.0005" smaller than the bottom tolereance in the book at work.
It will also need to be balanced as the knife edging and polishing will have unbalanced it.
I have a shitty pic, let me know if you genuinely want some better ones or of a specific area.
Price: $275 slightly neg.
pic:
I don't know how to edit first post, but the Greddy plenum is sold and the 6BOOST manifold Is sold PP. A lot of enquiries for the engine but is still for sale
  • 4 weeks later...
  • 1 month later...
Hey there... Just wondering if u still have the box... Pretty keen... Are u at Vic point in qld??? Would love to talk to u if u are!!!
Ryan. 0415885194
  • 1 month later...
  • 4 months later...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
