what alterations did you have to make to the wiring harness to get the motor running and the cluster reading correctly?
wiring harness was done by a workshop
to get the cluster/speedo working you need to use a navara sender. if you search there should be a few write ups on how it's done.
Couple of shots of the car from the Downshift meet last weekend. Car is currently just waiting on new set of wheels and a wheel alignment and then it's ready to finally roll. R33 front lca's are in, as well as new rear wheel bearings, rear traction arms and some pineapples to stiffen the rear end up.
with regards to your leaking sunroof, have you considered removing the glass/winding mechanism etc and replacing it with (slightly curved)perpex, any capable windscreen place should be able to do it
  • 1 month later...
Recaros are sold and got a r32 gtr passenger seat in the car and an old school Bride recliner drivers seat.
The Bride seat is absolutely fantastic. Massive improvement over the Recaros
Will give the car a wash and then take some hard parked shots later in the week.
Forgot to say, had the car serviced and re-tuned down from 16psi to 360rwhp at 14psi.
Clutch is going to need replacing soon and with my crappy tyres I still have no traction till 4th, so 14psi may buy me a few more weeks on the clutch.
Good stuff mate Im doing the 25 in my 32 too.. might try the gtr reo bar as well if you think it made much of a difference
You can see the difference in how it sat if you look at earlier photos.
With the gtr reo it sits perfectly
Cheers. Always thought the car was a bit untidy and half finished, but I take that as a compliment.
Had a work appointment close to home last week so decided to take it out for a spin instead of the work car so took a few hard parked shots while I was a bit idle
Then that same evening on my way home from basketball the clutch pedal dropped down to the floor and I could not get it into gear. Had a look and most likely the master or slave have failed as there was no fluid
So while I waited for my friendly RACQ towtruck to arrive, took the front bumper off so it's easier to get the car on the truck
It's not a big issue or expensive, just have no time at the present to fix it, which is a shame as I was hoping to make it out to the downshift meet on Saturday
There should be a lot more progress in the second half of the year as the car will finally have a secure garage to park in at the end of this month, or the start of next, so I will finally have some secure room to do some work
Step one will be to finish stripping the interior completely and sort out the sunroof
Hey mate, that car looks awesome. I was looking at doing this build myself (basically reshelling my current R33 into a 32) and I have been doing heaps of research on it. It seems that the biggest problem is the drivetrain as Im going to keep the R33 gearbox. I have a few questions about your set up, How much did the custom tailshaft cost, and how reliable has it been? I've just heard a lot of bad stories about the single piece tail shaft
Wow I think I now have a direction to head in with my R32 gtst. Will definitely keep reading this build thread! Thanks for the inspiration, you're car is sweet!
Thanks mate.
Haven't personally heard of any issues around single piece tail shafts. Mine has been faultless since the conversion, and I have been running nearly 400rwhp for the last two years, without issue.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
