what alterations did you have to make to the wiring harness to get the motor running and the cluster reading correctly?
wiring harness was done by a workshop
to get the cluster/speedo working you need to use a navara sender. if you search there should be a few write ups on how it's done.
Couple of shots of the car from the Downshift meet last weekend. Car is currently just waiting on new set of wheels and a wheel alignment and then it's ready to finally roll. R33 front lca's are in, as well as new rear wheel bearings, rear traction arms and some pineapples to stiffen the rear end up.
with regards to your leaking sunroof, have you considered removing the glass/winding mechanism etc and replacing it with (slightly curved)perpex, any capable windscreen place should be able to do it
  • 1 month later...
Recaros are sold and got a r32 gtr passenger seat in the car and an old school Bride recliner drivers seat.
The Bride seat is absolutely fantastic. Massive improvement over the Recaros
Will give the car a wash and then take some hard parked shots later in the week.
Forgot to say, had the car serviced and re-tuned down from 16psi to 360rwhp at 14psi.
Clutch is going to need replacing soon and with my crappy tyres I still have no traction till 4th, so 14psi may buy me a few more weeks on the clutch.
Good stuff mate Im doing the 25 in my 32 too.. might try the gtr reo bar as well if you think it made much of a difference
You can see the difference in how it sat if you look at earlier photos.
With the gtr reo it sits perfectly
Cheers. Always thought the car was a bit untidy and half finished, but I take that as a compliment.
Had a work appointment close to home last week so decided to take it out for a spin instead of the work car so took a few hard parked shots while I was a bit idle
Then that same evening on my way home from basketball the clutch pedal dropped down to the floor and I could not get it into gear. Had a look and most likely the master or slave have failed as there was no fluid
So while I waited for my friendly RACQ towtruck to arrive, took the front bumper off so it's easier to get the car on the truck
It's not a big issue or expensive, just have no time at the present to fix it, which is a shame as I was hoping to make it out to the downshift meet on Saturday
There should be a lot more progress in the second half of the year as the car will finally have a secure garage to park in at the end of this month, or the start of next, so I will finally have some secure room to do some work
Step one will be to finish stripping the interior completely and sort out the sunroof
Hey mate, that car looks awesome. I was looking at doing this build myself (basically reshelling my current R33 into a 32) and I have been doing heaps of research on it. It seems that the biggest problem is the drivetrain as Im going to keep the R33 gearbox. I have a few questions about your set up, How much did the custom tailshaft cost, and how reliable has it been? I've just heard a lot of bad stories about the single piece tail shaft
Wow I think I now have a direction to head in with my R32 gtst. Will definitely keep reading this build thread! Thanks for the inspiration, you're car is sweet!
Thanks mate.
Haven't personally heard of any issues around single piece tail shafts. Mine has been faultless since the conversion, and I have been running nearly 400rwhp for the last two years, without issue.
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
