I did the same Whatsisname. Replace my shockies with some new Bilsteins, then went to drop a mate off who helped me. Had a quick dorifto session in the backstreets (on a private road:)) then later realized only had the back nuts on only done up so far. Could've cried if i came to grief.....
PS - engine goes in next weekend (muahaha) :rant:
  • Replies 95
After thinking back to when my wheels last were removed I realised it wasn't the tyre dealer that was at fault in regards to my loose wheel nuts! Apologies to the business involved for the incorrect assumption.
The last time my rear wheels were removed and refitted was when I had the rear guards rolled. There was two adults present at time (me and the guy who did the guard rolling) I did NOT refit the wheels, so that leaves one other person.....
On a brighter note, it cost me a grand total of $16.80 for 5 new studs and $2 for one new wheel nut. Main North Nissan stock them both.
It took me and my neighbour (apprentice mechanic at Mercedes Benz) a bit over 1hr to do the job from start to finish. We broke another stud just getting the remaining nuts off! All the studs were bent.
Moral of the story? Always check for yourself your wheels nuts are tight whenever the wheels are refitted.   It could've been a very interesting sight... watching a 3 wheeled GTS25t @ over 200km/h
Yeh mate no shit, cos i was rite behind u and it wouldnt of been nice for both of us.
Anyway its great to hear everythin is sweet now. Ive already replaced my rear studs aswell, cos when i got the car, it came with rear spacers that had damaged the studs. So i changed them and took of spacers...
Mattr: on the cruise, it seemed matts nittos were too soft sidewalls which made cornering unstable (is that the word) or maybe the rear felt loose. Anyway ill let matt explain it but i dont think the nittos are the best for da streetz.
Yeah Dean it would've been very ugly with you and your GF wearing my 17*9 + Nitto in your laps!
Bl4ck32, I would've very pissed off with myself it I had of forgotten to do my wheel nuts up, I'm even more pissed that "someone else" did! Looking forward to how the new engine/turbo package goes mate :P Keep us informed!
Matt, as Dean mentioned - the Nittos soft sidewall makes the rear of the car "feel" unstable (probably a lot to do with having a loose wheel too!) I say "feel" because in reality the Nittos hold on very very well. I'd go as far as to say they grip as good as the 540's.
John was surprised, as he thought I was still on the 540s (I still have 540s on the front) I pushed a bit throught one corner and he said something along the lines of, "gotta love those 540s" to which I replied "they're the Nittos mate" :(
The big difference btw the two tyres is obviously the sidewall flex. It's pronounced enough to make the rear "feel" like it's moving around too much. The 540's have such a stiff sidewall (one of THE stiffest you can get!) that by going from one extreme to the other the sidewall flex is highlighted.
With ~40psi in the Nittos (I had ~34psi the other day) and tight wheel nuts I'd say it would feel much more stable.
To anyone thinking of using Nittos to go around corners, I can confirm they do actually have very impressive lateral grip, faaaar better than most normal road tyres. The fact that Nitto use the exact same tread compound and pattern for their circuit based NT555RII is proof of that.
Erica,
The "points" is the amount of cash that SAU withdraws from your bank account each time you post on the forum :( Naaa... but seriously, you gain points for each post you make. I'm guessing that these points can then be used to do things, sort of like a "frequent poster program".
Guest Miss_Nismo
Erica,
The "points" is the amount of cash that SAU withdraws from your bank account each time you post on the forum :thumbsup: Naaa... but seriously, you gain points for each post you make. I'm guessing that these points can then be used to do things, sort of like a "frequent poster program".
Doesn't that encourage pepole to post whore
Back to the topic, looked like a nice cruise. Pity my clutch decided to fail.
Trick, perhaps organise another day one.  That route looks much better to me in the day!
day time? much better at night its hard to drive 100% during day plus cooler at night and less distractions.you just gotta do it more so whats happening sat night im confused to whether people are going cruzn or not.perhaps "M1" garages should sort something out but i dont wanna tread on anyones toes if theres a cruz already im thhere but not a massive one and me is getting new treads sot gotta bed em in :boobs:
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
