As per interest in the Stagea Discussion section, I'm running a group buy on SuperPro suspension bushes which suit both M35 Stageas and V35 Skylines.
Parts that are available are:
Strut Bar To Chassis Mount Kit - SPF2849K - $146 - http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/part?id=SPF2849K
Control Arm Upper-Inner Eccentric Kit - SPF3297K - $152 - http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/part?id=SPF3297K
Control Arm Lower-Inner Bushing - SPF3298K - $83 - http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/part?id=SPF3298K
All bushes are being supplied direct from SuperPro.
Group buy will run for two weeks from today (23/1/2012) until 6/2/2012. Minimum order is 5 to proceed.
After the group buy closes, allow two weeks to arrive in Adelaide.
Parts can either be collected for those in Adelaide or posted at your expense. For those being posted, I'll post Express Post, flat rate $12.55.
If you have any questions please let me know.
Thanks,
Ryan
  • Replies 47
bigkevracer
jasevr4
bigkevracer
bigkevracer
Nightcrawler
Yep put me down for Control Arm Lower-Inner Bushing - SPF3298K - $83 - http://www.superpro....art?id=SPF3298K please - mine are screwed and I was about to order replacements out of the USA. Are we doing a local 'group buy' on pressing them in - I have been considering buying a cheap 10 ton press since I have been quoted $70 per SIDE to have them pressed in :(
Put you down Andrew.
I may be able to sort something out with the press - I'll check and let you know.
$70 PER SIDE? Can you PM me who that was? That's ridiculous!
I thought so too .... but the guy explained that the alloy in the lower controls arms is very soft and apparently it is a fair pain in the ass to do with a reasonable chance of lunching the arms and having to replace them .... nah I am not going to name names ...
bigkevracer
jasevr4
Dunc
bigkevracer
Dunc
bigkevracer
Nightcrawler
Dunc
Did mine with superpro a couple of weeks ago. Bought a cheap 6 tonne workshop press from supercheap ($99) and found that their calibre brand 30mm socket ($4.95) is the perfect size press tool to press out old and press in new. Didnt have any trouble with soft alloy at all.
I've had an offer from SuperPro to ship to everyone direct. Cost is $16 for a 3kg overnight airbag.
Since everyone so far is in Adelaide I don't think it's worth it, but if you'd prefer yours shipped direct let me know.
No worries Brad. Kind of funny everyone so far is in Adelaide...
bigkevracer
jasevr4
Dunc
ducati02
bigkevracer
Dunc
ducati02
bigkevracer
Nightcrawler
Dunc
ducati02
bigkevracer
jasevr4
Dunc
ducati02
Commsman
bigkevracer
Dunc
ducati02
Commsman
bigkevracer
Nightcrawler
Dunc
ducati02
Commsman
Good news!
We have changed the supplier for this group buy, which makes everything a bit cheaper and easier for all of us.
The new supplier is JDM Obsession, an SAU Trader.
Prices have been dropped to the following:
SPF2849K - $139.00
SPF3297K - $148.00
SPF3298K - $79.00
Freight is $12 shipped direct to you, otherwise if you're in Adelaide you can collect from me and save yourself the freight cost.
This works out a bit cheaper, and every bit counts!
If anyone has any problems at all, please PM me. This won't effect dates and delivery times for the group buy at all.
Ring back the first supplier and see if he will beat the new price. Could have a price war. Both companies are trying to get the business. When do you want coin?
Don't worry, I spoke to the first supplier about it! That's the best I can do at this point.
I was going to wait until all the orders are in before I start getting coin, but I'll start contacting people shortly.
Where in Adelaide are you Ryan? If you are not North I might just go the $12 shipped option, which would be easier than running around to pick them up.
I'm going to borrow my brothers spare press if anyone wants to join me in swapping them over. In Adelaide that is. Seeming that most of us are out north we could get a production line going.
Guest
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
