Hi All,
Up for sale is my 2001 R34 GTR VS2. I have owned this car for the last 3 years and like most GTR owners, have barely driven it. I had big plans for this car when I first got it, but never got around to doing most of it as time and money constrained me I lost interest. Late last year it developed a couple of problems, outlined below:
1st problem: Originally thought this problem was turbo seals, but on further inspection it was low compression in 6th cylinder, compression test came out 150 150 150 150 150 35. I took the car to the mechanic in early November for him to diagnose and repair the issue, the issue was suspected as a burnt/chipped valve (as fuel vapor was being pushed out of the pod filters when throttle closes) and the plan was to get a camera and insert it into the 6th cylinder to check for scoring on the cylinder walls if the valve had completely dislodged, which would mean the block would have to be replaced. However almost 3 months later and he was unable to get a camera that would show enough detail, so because if the block was opened I would be forced to repair it before I could sell it, I decided I would simply sell the car "as is" to someone looking for a cheap vs2 they could build up easily. The car is currently drivable.
2nd problem: Airbag light flashing. I don't know why. The car has obviously never had a front ender, the airbags have never been deployed and there is no reason it should be flashing as far as I can tell.
What I have tried to fix the 2nd problem:
Manual reset through the door open/close button (didn't work)
Guy with Consult system try to reset (no idea if it was a Consult I or Cosult II) - from my understanding you need a Consult II for R34 GTR's post '00
Plug in standard ecu and connect laptop with "Conzult" (free 3rd party consult ripoff) through diagnostics port - software said it "couldn't connect to ecu" (as in the standard ecu - it didn't even get to try to read errors) which more than likely meant the software was junk.
What more than likely is required:
Trip to Nissan to have genuine Consult II system hooked up to diagnostic port and reset airbag ECU, which may or may not be possible with PowerFC installed, so borrowing a stock ecu may be required.
Other possibilities:
Airbag ECU needs replacing
Some fault in wiring somehwere (It's possible some wiring was partly damaged when headunit was installed, so problem didn't show up until later on but this is unlikely)
Faulty sensor somewhere
Fuse burnt out somewhere? (I have no idea if there is one for the airbag system or not)
Description:
Year: 2001
Model: Nissan Skyline R34 GTR V-Spec II
Colour: Black
Kms: 110,xxx (approx)
Rego: 01/11/2012
Modifications:
Electronics:
Apexi PowerFC
Blitz SBC SpecR Boost Controller
Kenwood AVIC-F90BT In-car navigation & stereo
LED Tail lights
Nismo 320km/hr Dash
Xenon Headlights
Mechanical:
Tomei Sump Baffle
Nismo N1 Water pump
HKS Twin plate ceramic clutch
Tomei Poncams Type B camshafts (260degree)
HKS Camgears
Trust - Greddy Lightweight Pulley Set
Ross Tuffbond MetalJacket Harmonic Balancer
Twin SSQV Bov's
HKS GT-SS Twin Turbos
Apexi Header pipes
HKS Dump Pipes
5in Metalcat
Trust PE Ti 3in Titanium Exhaust
Nismo 600cc Injectors
Trust remote oil filter relocation and oil cooler
Apexi Power Intake Pod filter (x2)
RB25 Airflow Meters
Nismo Engine Mounts
Nismo Transmission Mounts
Handling:
AP Racing CP5000 4pot Front brake calipers
Aesthetics:
Border Racing dry weight carbon fibre bonnet
Carbon fibre radiator cooling panel
Nismo carbon fibre side pillars
Nismo floor mats
Nissan rain shields
Genuine Nissan side skirts
Spares:
Original floor mats
Front wheel well plastics (one side has a small hole in it, so I bought one in better condition)
Spare 3in exhaust
Spare front diffuser (scratched)
DBA5000 Rotors (front 2)
Brand new OEM Coilpacks
Service History:
Log books since cars arrival in country at ~25k kms (2005) until I took possession of car (early 2009) (log book was full when I went to do 1st service, have completed 2 services since I've owned the car).
100k km service completed under 3 months ago, at which point all major seals/gasket replaced besides headgasket/turbo gaskets (bought a OEM nissan gasket kit), harmonic balancer replaced with ross item and pullies replaced with lightweight items
Price: $45,000 ONO
Contact via PM or contact me on my mobile
post-19783-0-61879800-1327566587_thumb.jpgpost-19783-0-75300000-1327566600_thumb.jpgpost-19783-0-90230900-1327566621_thumb.jpgpost-19783-0-06507500-1327566633_thumb.jpgpost-19783-0-52776700-1327566642_thumb.jpgpost-19783-0-48869800-1327566690_thumb.jpgpost-19783-0-93473900-1327566700_thumb.jpgpost-19783-0-10502200-1327566789_thumb.jpgpost-19783-0-09208700-1327566794_thumb.jpgpost-19783-0-47059200-1327566798_thumb.jpgpost-19783-0-66912600-1327566802_thumb.jpgpost-19783-0-31423000-1327566808_thumb.jpgpost-19783-0-41161600-1327566813_thumb.jpgpost-19783-0-75645600-1327566818_thumb.jpgpost-19783-0-48233400-1327566823_thumb.jpgpost-19783-0-62802000-1327566828_thumb.jpgpost-19783-0-21770700-1327566832_thumb.jpgpost-19783-0-37449000-1327566891_thumb.jpgpost-19783-0-29876000-1327566899_thumb.jpgpost-19783-0-72057400-1327566904_thumb.jpgpost-19783-0-57776600-1327566911_thumb.jpgpost-19783-0-75848400-1327566915_thumb.jpgpost-19783-0-85718500-1327566920_thumb.jpgpost-19783-0-61080200-1327566924_thumb.jpgpost-19783-0-79732100-1327566928_thumb.jpg
haha JP! Can't believe you are selling the 34 gtr now. Should buy your old supra back man I test drove it, it went very good. Can't beat toyota's reliability bro :) Anyway good luck with sale :)
where were was this few months ago , would of bought it for sure , very nice car mate
quick question did you buy the car with the separator installed if not how much did it to get installed?
either way good luck with the sale! :thumbsup:
Thanks all for the strong interest in the car :)
Unfortunately I never really got to enjoy it, sitting in the garage, sitting at the workshop for mods or sitting in traffic in the few times I drove it around. So now it's time to get a nice runabout instead.
nice car ive seen it couple of times at paden shop =]
Thanks!
Cheers mate :) The seperator was already installed, but the hardest part of it seems to be the mounting, bit of creative bracketing and it should be fairly easily replicated!
this is good for someone wanting to do an rb28 stroker kit
Cheers mate, my thoughts & hopes exactly! Would love to see the car given the proper build treatment it deserves!
One point of relief for the new owner could be this:-
My previous R34 GTR also a VS2, had a airbag warning light that wouldn't go away despite the approaches you took.
I just needed to replace the airbag ECU under the centre console > Voila!
Make sure that the unit is the series 2 one; because the series 1 is different and the loom won't fit
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
