MOTOR Performance Car Of the Year
I dun even realise my subs to the mag expires, they didn't even let me know... normally I receives it mid month, now it's over the 20th of sept and still havnt received my oct issue... so I just bought one tonite merely due to my interest on XR6 turbocharged version and 2002 POCTY article.
Still considering if I wanna renew or not, coz my bro buys wheels and content is pretty much the same.... sometimes get sick of reading those two mags at the same time.....
What you guys think of "Speed", they've only got 2 issues so far...
2nd issue got that 600kw yellow R33 GT-R....... yummm......... $300K spent on mods.... I feel it's a good break from HPI & Motor since it's articles are a mix between import cars & local cars.
Hot4s got too many airbrush showcase n I'm not into airbrushing my car.... Motor is good, Wheels I found is like Motor wannabe, oh well...
Originally posted by GTS-4OrCeD
Motor is good, Wheels is terrible most of the time.
I think I will subscibe to HPi and Motor.
Greg. :devfu:
i would say wheels will catch up to motor pretty soon as the old editor of motor (ged bulmer) is now the editor at wheels...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
