hi guys im after a rb25 stock turbo to put on to my rb20 if anyone could help me out would be great cheers matt
please text me on 0402948881 thanks
Edited by TwinTurboSupra+R32 Gtst
https://www.sau.com.au/forums/topic/389687-r33-stock-turbo-in-good-condition/
Mate I have a stock RB25 turbo that I took off my RB20, only took it off to put a highflow on, don't know how old it is, it was on the car when I bought it, but it spooled up fast and made pretty good power at 11psi.
