Per the title and photos. These are in perfect condition save for some insignificant scratches. These have been in my car since 2009 and were bought with track & tarmac rally in mind. They were purchased and fitted brand new from Techsport in Bayswater in 2009. I have different plans for the car now so the original stuff is going back on and some of the add ons are being sold.
Spring rates are 8.0 Front / 6.2 kgf/mm Rear or 448 / 347 lbf/in. Springs are non-linear. More information here www.dmshocks.com. Height adjustable, independent compression and rebound dampening adjustment. Comes with instructions and adjustment tool.
The car these were fitted to is rarely driven so have had little use. They include some custom fabricated tops (not spherical bearings) done by Techsport.
$2,500 and I’ll post anywhere at your expense. You’re welcome to make reasonable offers as I’m unsure of the market price but these have been off the car for around 6 months and I’m not in a rush, so don’t expect me to fall in love with the first low ball offer.
Any genuine questions or enquiries are welcome via PM.
https://www.sau.com.au/forums/topic/389860-dms-50mm-coilovers-to-suit-r32-gtr/
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
