hey guys, been thinking of putting a diffuser on the GTR...
seen a few styles around and im not sure if i can see it suiting mine, wondering if anyone has some pics to point me in the right direction
so far what iv seen
http://jsai.com.au/c...t/diffusser.jpg - not a fan of this looks way to cheap
http://jsai.com.au/c...42d62465f4c.jpg - anyone have pics of the top secret one on a r32 gtr?
here are afew pics of my car to help with visualizing
:cheers:
https://www.sau.com.au/forums/topic/389950-r32-gtr-rear-diffuser-choices/
Can't say I really like the diffuser on a R32 GTR.
It kind of ruins the 'Streamline' looks of the R32 and looks a tad out of place.
You can get a way with it on a R33 GTR as it is a larger car with it's 'Stylish' looks as well as the R34 GTR with its 'Aggressive' looks.
But from a Function Over Form point of view, it will help out the R32 GTR with better aero dynamics.
Diffusers do not look good on a R32. Full stop. Front or rear for that matter.
BUT, on a R33 GTR, it's a whole new different story...
http://www.skylinesaustralia.com/forums/topic/352106-r33-gtr-rear-diffuser/
The top secret rear diffuser is on their official website mate, you can download a catalogue on a pdf file for part numbers. Ive seen them on ebay from time to time also.
By the way, I saw your car in the flesh at the hotel in Shepparton last year for SAUnats. Looked very nice, and added some sting to the fact that I couldn't get my GTR there for the event!
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
