Hi, before anyone jumps in, I have read about 20 different posts in relation to this and none of them are exactly the same as mine.
Started the car today, from first crank it had a persistant tick/click sound like tick tick tick tick and even with throttle it was there and it increase in volume & speed as the throttle increased (using the throttle cable in the engine bay)
(R33 S1 auto, stock turbo, stock inj, stock engine)
I waited a good 5mins before driving the car, opened the hood and my ear was directed towards the top right hand side of the engine bay between the turbo and the wall/flywheel. couldnt exactly pin point but it was louder right there in that corner.
At first I thought it would go away but I had some business to take care of, SO i drove the car 45mins and the click/ticking continued, was faint when driving unless I went pass a car or in a tunnel, but it was still making the noise whilst I was driving the whole time, as well as on Idle parked.
At first I thought it was the lifters but lifters usually sound deeper, then after reading i am thinking it may be a big leak in the exhaust/turbo gaskets causing the noise, as it increased with throttle as if it was controlled by the air passing thru the exhaust.
can anyone shed some light at tell me if its likely to be a leak as it made the noise in Idle and driving, no matter what rpm or speed I did. and its coming from the right side of the engine near the turbo/exhaust!
any advice would be appreciated, its possible gasket or bolts have snapped and caused a leak??????
please help, as I just got myself Z32+nistune today ready to be tuned, but cant do a tune till I sort this out! hoping its just a leak and not lifters! ( it made this noise before I changed ECUs)
thanks heaps
You couldn't have read too many threads...
Exhaust manifold gasket has blown. You'll need to replace it.
Also replace ALL manifold studs at the same time, you will likely have a few broken ones.
thanks, just wanted to be sure if it suited mine, and where do I get these parts & prices thnx
Thanks
Ordered Exhaust manifold gasket and the stud kit with all studs/washers etc, will update when they arrive and are put on, that could also explain the low power,
OH then I am getting my new nistune TUNED soon also :D happy happy!
Get the number of a stud remover ready, there is a high chance some will break. My old car, 120xxxkm, all came out smoothly. Amazingly.
How much did the parts cost you?
Edited by SargeRX8
Mine had a similar problem, it turned out to be a loose wastegate, over time the actuator had lost its preload. Easy way to tell is to start the engine (preferably cold) and pull on the wastegate arm and see if it stop. Worked for me! :)
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
