Hi, before anyone jumps in, I have read about 20 different posts in relation to this and none of them are exactly the same as mine.
Started the car today, from first crank it had a persistant tick/click sound like tick tick tick tick and even with throttle it was there and it increase in volume & speed as the throttle increased (using the throttle cable in the engine bay)
(R33 S1 auto, stock turbo, stock inj, stock engine)
I waited a good 5mins before driving the car, opened the hood and my ear was directed towards the top right hand side of the engine bay between the turbo and the wall/flywheel. couldnt exactly pin point but it was louder right there in that corner.
At first I thought it would go away but I had some business to take care of, SO i drove the car 45mins and the click/ticking continued, was faint when driving unless I went pass a car or in a tunnel, but it was still making the noise whilst I was driving the whole time, as well as on Idle parked.
At first I thought it was the lifters but lifters usually sound deeper, then after reading i am thinking it may be a big leak in the exhaust/turbo gaskets causing the noise, as it increased with throttle as if it was controlled by the air passing thru the exhaust.
can anyone shed some light at tell me if its likely to be a leak as it made the noise in Idle and driving, no matter what rpm or speed I did. and its coming from the right side of the engine near the turbo/exhaust!
any advice would be appreciated, its possible gasket or bolts have snapped and caused a leak??????
please help, as I just got myself Z32+nistune today ready to be tuned, but cant do a tune till I sort this out! hoping its just a leak and not lifters! ( it made this noise before I changed ECUs)
thanks heaps
You couldn't have read too many threads...
Exhaust manifold gasket has blown. You'll need to replace it.
Also replace ALL manifold studs at the same time, you will likely have a few broken ones.
thanks, just wanted to be sure if it suited mine, and where do I get these parts & prices thnx
Thanks
Ordered Exhaust manifold gasket and the stud kit with all studs/washers etc, will update when they arrive and are put on, that could also explain the low power,
OH then I am getting my new nistune TUNED soon also :D happy happy!
Get the number of a stud remover ready, there is a high chance some will break. My old car, 120xxxkm, all came out smoothly. Amazingly.
How much did the parts cost you?
Edited by SargeRX8
Mine had a similar problem, it turned out to be a loose wastegate, over time the actuator had lost its preload. Easy way to tell is to start the engine (preferably cold) and pull on the wastegate arm and see if it stop. Worked for me! :)
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
