I have been installing quite a few Varex mufflers lately with the sound control valve. I was impressed enough to buy the 3.5 inch muffler for my own car with a 3.5/5 inch mid muffler. Quiet at the press of a button.
  • Replies 57
Posted Images
What are they charging for the varex muffler?
Have u done any hooker mufflers? Opinion?
Best mufflers do the 3.5 inch Varex for around $400.
Haven't done a hooker, mainly because the stainless ones are hard to find cheap. They aren't a straight through so not sure how they will flow either. The design looks good though, I would like to try it one day.
Good mufflers are hard to find, especially large bore ones.
Also been looking for a while...tossing up between Kaki 06&R + Xforce dump, or just getting the works from CES...
so Xforce make 3.5 dumps?...what about front pipes?
noob question what's a hooker? I'm pretty keen on the varex cause I pretty much share my garage wall with next door and im up at 5 so yeah don't wanna be a jerk
It's a brand of muffler I like to use them they sound very decent. I'm not a fan of the varex they put the tune out not keen on pressing a button if I want to have a go rather just put my foot down
The tune goes out Blake? Have you actually seen it happen?
From the cars I have fitted them to with widebands, the tune is fine. Obviously the boost is lower and top end power is down.
I will test the 3.5 inch system out on the dyno to see the power loss firsthand and any tune related issues that might arise. Just being able to quieten a 3.5 straight system to near oem levels impressed me enough to give them a go.
When you full close the exhaust it will cause restrication making it quite I'm sure when the car is dyno tuned I'm sure it will be tuned fully open so no restriction. I'm not sure how much it would change it may or may not cause det issues but there is deffinatly a restriction caused when closed. This was enough to make me steer away
Of course theres a restriction, theres no way a 3.5 inch straight through will be quiet without one. I think it would be a great setup if you could hook it up to the ecu for load actuation, or apparently there is an addon Xforce sell that automatically actuates the valve on engine revs also. (similar to what Ferrari etc use)
My question to you is, can you guarentee a customer the Hooker system is quiet enough to not get dicked? They are built for the "note" V8 guys want, just like Magnaflow mufflers and unfortunately that makes them too loud in most cases.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
