Nissan (350Z) Import Fairlady Z 2003
Engine
VQ35det 6 Speed
[email protected]/8psi" [email protected]/8psi boost
ORC super single clutch
Full HKS 3037pro turbo kit (screamer pipe)
HKS injectors, 660cc
Tial 50mm BOV
Heltech 350Z Platinum pro plug and play
GReddy Bspec 2 boost controller (7.5/8psi)
Fujitsubo Legalis R exhaust
Walbro 550cc fuel pump
Trust oil cooler with remote filter
Braided clutch line with new slave
Exterior
Full vertex body kit
20x9.5+6 Front, 20x10.5+0 Rear, Work VS-XX rims
Rear LED 350Z lights from the 07' model
Carbon Fibre roof lip
Carbon Fibre Garnish door and mirror pillars
Carbon Fibre Aerial
Carbon Fibre Air Intake Duct
Belloff HID 9000K HID lights
LED parkers
Tinted windows
Suspension
Tanabe GE sustec pro adjustable
SPC rear camber arm
SPC traction rods
SPC toe bolts
Replaced front standard bushers with nylon bushers
Interior
Z floor mats and boot mat
Nismo GT shift gear knob
Z aluminium side steps
Nismo gear H pattern
Stereo
Pioneer 6.5inch TV/DVD/MPZ player
Alpine amplifier
Pioneer 6inch carbon fibre front splits
Pioneer 10inch subwoofer.
will come with rwc and rego
car is in brisbane/gold coast area
also comes with a standard set of wheels
this is also the only (350z) import that is road legal in australia that i no of...
most mods done in the last 6months
crack in front bar will be all fixed before sale
car has 13x xxxk's on it
motor has 72 xxx on it
$37 000ono with rims
$33 000ono with out the work rims
Rossi 0401567736
NO SWAPS
Edited by 12slide
https://www.sau.com.au/forums/topic/391580-nissan-z33-350z/
OP... Y U NO sell this a month ago?! Is exactly what I was looking for but eventually gave up lol. Goodluck selling this monster :)
It was for sale a month ago just not on this site...but cheers..
https://www.sau.com.au/forums/topic/391580-nissan-z33-350z/#findComment-6239939
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
