Just wondering, who here is aiming to attend this event?
Open to all vintages - Is a SAU group attending? Sorry haven't been on for a while.........
For the record, I'm attending in the (r34's old) DR30 (my HR31 is no go just yet).
Cheers,
Mike.
Edited by Union76
https://www.sau.com.au/forums/topic/391729-okay-whos-going-down-to-dandy/
Hey Mike,
Thought you might have been at Hanging Rock on Sunday - it was a great day!
I'll be at Dandy showgrounds - and am taking a couple of cars. We should have around 15 Prince's there all up - 1 of each model GT, Gloria Wagon, Gloria Sedan, Prince Skyline 1500 Estate, KGC10 GT-R Replica (although it is staying on the back of the truck) and the only 1st gen Skyline.
Should be a great day!!! Hope the weather holds up!!!!
See you & Julie there :thumbsup:
Hey Jason,
Ahhh there's nothing like a couple of good Princes on show...... Spot on.
Yeah sorry we didn't turn up, we've done H/Rock the last few years and decided on a break this time round. How'd the Roo Stampede go?
Mike.
howdo,
You're keeeen, excellent. The DR count may have just increased! I think I read you're running down with r31club - feel free to join us -ndsoc if that's not the case. Sure Jason can fill you in on the details.
Yes I've been copping a bit of sh#t for not attending H.R. I guess I got to the stage where the amount of Mustangs in my diet caught up with me, needed a year off to help with digestion!
Mike
Edited by Union76
RE: the rock and mustangs,
yeah I feel your pain, but tehers heaps of the cool things there!
Its abit of a tradition I go down there now, the old man has a few toys.
Wasnt really going to cruise down with the R31 guys, just a solo cruise down.
Should try get the R30's together again.
And woot, Im now on club rego :devil:
howdo,
Mike
NDSOC are meeting at Keysborough Macca's for a 9am departure. Prince guys will be there earlier to set up and unload a couple of trailers......
CSA also have a good number going....
Should be a big day!!
Im a maybe now, unless I can get a new reinforced sump on the fj,
copped a good hit in the hills and got some oil pump whine :yucky:
I did this the oil pressure stayed a little lower too. i beat it back out (space for the pickup..causes noise/starvation) i braced mine with checker plate!
it was not overly hard in the end
Marc,
its a straightfoward job, have a welder, would rather get another sump preped for a quick swap as i cant have the car out of action.
thanks for the offer cazz, but would to like to buy one :)
I might take it as is, and plan the route there avoiding shitty roads.
Looking like a good r30 turnout :cheers:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
