  • Replies 63
might have to come down to this skid pan day and meet all these people making such a fuss.
Perhaps you should re-read this thread from the beginning (that's starting from page 1 and working your way down in case you don't get it) and see who's actually making the fuss.
You barged into this thread and out of the blue, and completely uncalled for and unprovoked... you posted uneducated drivel, insulting us for taking our cars to skidpan days
Go back and read the progression of the thread and see where it all started.
sorry jackson i didnt insult anyone i just stated my opinion, is that a crime in australia, anywys im over it, i think its time for a new hobby.
Well perhaps it was the way that you said it that got everyone upset.
Think about it. Look how many people got defensive and upset at your post. Where do you think the problem lies? With the 15 people who got angry or the 1 person they're all replying to?
well obviously its the 15 people who got defensive, and why do would they get angry about a skidpan comment, if anyones up for the challenge and wants to say something to me please i dont mind ill show you skidpan on your face. i mean if someone is really offended come out and message me ill give you my number and you can make a formal complaint.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
