Right so........ Was following my missus to hospial a couple weeks ago and whilst trying to call her mum i smacked a square gutter...... HARD (lesson learnt about using phone whilst driving also i frickin hate Gungahlin) the dowside to this is ive bent the rack end rod that comes out of the steering rack, I was hoping it was just something stupid like a tie rod end but alas i have terrible luck, any idea how hard this will be to fix, one mob has told me to replace the entire rack, which wont be fun, any idea if just the rods fixable??
Cheers
Josh
https://www.sau.com.au/forums/topic/392377-little-help-i-bent-it/
I did something similar 3 Christmas' ago to my R33 GT-R. I thought it was a simple castor rod replacement. I replaced the rods for $180 through trojan and continued to drive it. But it just felt wrong. It didnt handle the same, kept pulling to the left no matter how much adjustment was made through the castor rod. Wheel alignments were useless. Anyways, long story short, I have had to replace bent upper and lower control arms, wheel hub, reconditioned the steering rack and finally the cross member subframe. Things we do for love right ?
hmm....my car seems to pull left no matter what as well..... :(
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
