  • Replies 162
howaitonaito I have sold the the clock trim and gear knob. I have the gear stick if that's what you need and also the wood grain trim from the door trim. If yours is broken i guess you could paint it black.
carbon wrapping them along with the silver strip on the gear stick and clock surround. Is there anyway you could bundle them up and do me a deal, not sounding like a total tight ass
Hey mate was wondering if I could come past and have a pick through what's left of the car just after a couple bits here and there, either tomorrow or sat?? Whatevers good for you shoot me a txt 0415202633 cheers
Hey Chad, its me again, just wondering if you have the spare wheel cover struts too? i just realized when you pull the leaver its meant to pop up by itself, mine does no such thing :P
If you do and they are in good working order, let me know!
Cheers
Ken
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
