Just quick question when someone like me (new to the turbo scene)
Buys a stock gts-t what would be the best way to get more power out of it for around 10K like I know the standard stuff but what is a nice lil unit turbo wise that seems to have a all round quality to it?
other than that it's inter cooler bigger injectors and after market ecu that will give you the gain yeah? And is it worth just getting the internals of the stock turbo upgraded to ball bearing?
Thanks for your time guys hopefully one day I can actually join in a turbo debate and know wtf is being said :mad: lol
ignorence is not bliss lol :rofl:
Cheers.
https://www.sau.com.au/forums/topic/39254-has-this-question-already-been-asked/
i would say with 10k
I/C (possible gtr cooler or hybird)
ECU (wolf3d, powerfc, depending on power lvl u might be able to get a chip ecu or a safcII)
Rebuild would be also a good idea again depending on how high you want to go (r33 with sotck internals made 411rwhp)
HKS GT25 - i would say would be a good turbo not 2 laggy and should give you somewhere around 300+ if u want 400 to 500 then you will be a gt30
mike hope this helps :mad:
cheers mike that's what I thought yeah I was just hoping for something average so had the power when I wanted to play. so around the 220/250rwkw maybe?
But that advice is great thanks
Thanks squizz well for 10K if I gave you the car and you brought back a weapon the hell take it lol but wait till I get the money lol oh and the car lmao 2 months :mad: Just doing my home work for now :rofl:
2 npz arian :mad:
If i was in your shoes i would do rebuild, Forget piston,cam, cam gears, strenght rods. Then ecu and gtr cooler (gtr coolers r good for alest 600hp), and if there was money left over a hks gt20 or some sort of turbo rate at about 400hp
Best thing you can do is forget all the advice you just got except the bit about reading the stickies they are where you do your research. The stock R33 turbo is ball bearing. Before you start building it's best to know what you are building on,
ps oh!... and especially don't give your car and $10K to Squizz........give it to me............or maybe just the $10K :wassup:
1. panel filter with cold air induction ~$200
2. Custom m.s 3" turbo back exhaust ~$1100 fitted
3. Hybrid FMIC with piping ~$1200 fitted
4. Bosch 500hp Pump ~$400
5. Injectors ~$750
6. Electronic Boost Controller - AVCR ~$600
7. New ECU PowerFC with hand controller, Tuned ~$2000
8. New Turbo ~$2500
9. Suspension Mods - King Springs with Bilstein shocks - ~$1500
10. Brake Upgrade - DBA Slotted rotors with good pads ~$1200
That goes a bit over the $10 000 budget to around $11 500. Probably allow for about $12 000 to have an all round, reliable, quick street car. I think 220-230kw atw is achievable.
Depends if you want to do some mods yourself too. Tuning will cost a abit depending on what order you do the mods in or if you do them all at once :headspin:
Guest INASNT
pointless getting boost controller and power fc, might as well get a wolf3d with built in boost controll
No once again u have given wrong info.
Power fc and boost controller is fair superior to a wolf 3d.
Also u wouldnt waste time building a strong engine with forged internals then chucking on a pissy 400hp turbo.
ARIAN
For $15,000 u can get 300rwkw without having everything maxed out like stock fuel injectors etc.
nice I was only after 220-250 rwkw for a everyday driver that has the poke to get up and dance on the weekend. But 300rwkw is a nice round number.
Cheers to all so far this is good info I know the sticky threads cover most this but I just wanted a quick simple list of engine mods with out sorting through all the non importaint stuff :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
