Group Buy, New R33 Front bar.
  • Replies 54
I am very interested, but would like to see a picture of it on a car to be sure.
Dont take this the wrong way, but what is the quality of the bar like? My car is beeing painted by one of the top (most fussy) painters in SA, and if it dose not sit in correctly, or isnt straight he wont touch it. (dont want to waste your time and money shipping it back to you)
I am going to pair it up with an impule bodykit, but I am unable to get a front bar at the moment (nor for the forseeable future), hence the need to look at alternatives.
PS what would it cost to ship it to Adelaide? (in the next week (2 weeks at the most))
Guest MFX_R33
My car is in pieces at the moment (and has been for 8months) and wedged in a corner, so you wouldn't see much.
As for the aero dynamics, the bar is designed to give a good amount of front downforce, and is also designed to go with the carbon fibre cannards we are currently finishing off.
The bar is also designed around a 600x300 intercooler, so you can receive maximum flow.
Jeff.
i just wanted to know where u tested its aerodynamics. as to do this properly you would need to put it on a car then put it thru a wind tunnel you would also have to put the original car in a wind tunnel to see the differences in downfoce. Only monash clayton has these facilities in australia. the wind tunnel their goes to 200 km/hr. and its very expensive to hire...
dont want to start a nerd-fight in someone elses thread - but you sir, are a goon!
Guest MFX_R33
No we have not tested the bar for exact aero dynamic properties. As I said we have "designed" it to give a greater amount of front down force, using the wing shapes on either side of the bar, and as I mentioned before, with the optional carbon fibre canards.
If someone on here wants to know the drag coefficeint of the car before and after the kit, they would be hard pressed to find it for any kit. This factor will also change for most cars at any rate, as it depends on may other factors as well, including ride height, and the other aero parts they have fitted to their car.
This said, most people buy body kits for purely cosmetic reasons. We are offering an alternative to the limited range of R33 kits available in Australia. There are very few companies in Australia producing NEW stuff. If you like it that's good, if you don't that's fine too. We are just offering you guy's another choice.
Jeff.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
