It "could" but it really depends on how high your compression is and how much of a threshold it will have for pre-igniting the mix with boost on board. You might find that at 5psi, with some cheapo ducting to try and cool the comp housing, high octane fuel and a few degrees of timing knocked out that it's safe enough but you'd need to monitor knock very closely as I doubt standard Elantra piston ring lands would sustain high levels of knock for extended periods, the real concern though is preignition as it will melt holes in shit before you realise there's an issue.
For the cost of a cheap cooler, you can likely keep the timing where it is and not sacrifice response, run 5psi safely enough, and not have the heartache. Bare in mind that 5psi or not, tuning of "some" sort will be required. You might get away with an SAFC or a Jaycar fuel controller but you will need some way of giving it more fuel than the factory ECU will think it should have at a given point. Without knowing how big the factory injectors are (my guess would be 240-270cc or so) it's hard to know what other hurdles you might follow.
Don't let anyone tell you it can't be done or that it's stupid, if you have the time and money and desire, do whatever the hell you want.
Edited by ActionDan
Totally wrong turbo. A td05 on a 2.0 or 1.8 will not spool well. On an rb20 it spools at about 3 but that a long wait for just .5bar, trust me I've had to put up with that for a while now.
They would work well but im pretty set on a kando atm. U can use the following vid as to boost reference spool times with a td05.
Different car but same motor
Anyway I wont ramble on about a hyundai in a skyline forum to much longer
Ill start a build thread when i start turbiing it. Thanks for all ur help guys
Early 90's Subaru Liberty/Legacy RS Turbos used a water to air intercooler.
you can buy the whole kit for under $100 I'd say.
They seem to be good for about 160awkw on the subies using a TD05 (a mitsu one.. not Kando).
Looks like this in the engine bay
it then pumps the water/coolant to a thin condensor/radiator out the front.
Looking at the pic of your old car, you could easily fit the cooler part in that front passenger side of the engine bay.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
