does anyone know of any MFD's that show water temp, oil temp, oil pressure, boost. or any others that work with the Stagea? other then a GTR one? will be good if it shows gauges. or bar graphs. or if there is anything else that will work that is not too expensive.
https://www.sau.com.au/forums/topic/392773-mfd/
going with a nistune ecu now. so will need to work along side that. do u know how hard it is to wire up? or is it consult cable like others?
Informeter plugs into the OBD plug. I'm not sure exactly what it will read on a C34, I've only used mine on an M35.
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248441
Engine temp, injector duty cycle, throttle opening, AFM voltage, ambient temp, RPM, Speed, O2, and a bunch more. With additional sensors you can do oil temp, oil pressure, boost pressure etc.
Link;
http://www.greddy.com/products/electronics/informeter/
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248577
HKS CAMP 2. straight OBD port and does video onto a screen (I'm assuming that is your question.)
Just did a google on this, and saw that it needed a Nissan Consult cable for our cars... Now is that to connect our nearly OBD II conection straight into the CAMP2, or does it convert it to an OBD II format that the CAMP 2 normal connector can read?
Now, just say it did convert it to ODB II, does that mean it would work with the Garmin Bluetooth dongle thing....
Got to ask... :thumbsup:
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248768
the M35 might have the OBD connection already. but the C34 i know need the consult cable to enable it to plug into the OBD connector that comes with the camp 2 nd most other diagnostic tools. as the consult plug is not the same. OBD is 16 pin. not sure about the early nissan ones. haven't counted
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248774
I'm pretty sure Jetwreck tried one of those in his M35 and it didn't work. Maybe PM him to check?
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248780
Yes, the HKS cable plugs straight into the OBD2 port and either the CAMP2 or the Fcon iS. From there it is a video signal out to a screen.
The connection on the HKS equipment is like a modified RJ11 (home phone).
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6249241
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
