Parts are leftover or surplus from an engine build and no longer needed.
Rb26 crank out of an r32. Good condition and will supply a crank collar that the buyer can put on. $450
2 x standard turbos, with wastegates and dumps. Very minimal shaft play. $350
Standard rods/pistons, good condition. $200
Complete engine mounts $90
Complete sump with diff and baffles still in place $300
Fan with clutch, all fins in good condition $90
6 x standard injectors $200
Standard ecu $95
2 x air filters, unknown brand. They have never been used and have the adapters to bolt to the afms attached. They are fairly large (around 4inch diam) and are made of chromed plastic. $40 for both.
2 x blitz blow off valves still attached to pipe $220
2 x standard blow off valves still attached to pipe $70
Engine valley cover and front timing cover. Both in original black paint and in good condition, $100 for valley, $80 for timing or both for $160
2 x standard afms, great condition with plugs and mesh still intact. $200 for both
Greddy clear front timing cover, new never used (they don't make these anymore) $110
Standard power steering pump $100
All items located in Thomastown, Vic. Can arrange freight at buyers expense.
https://www.sau.com.au/forums/topic/392957-rb26-parts-for-sale/
How much for cost of postage for Complete sump with diff and baffles to Sydney 2000. Many thanks.
The sump is pretty heavy, I reckon would cost about $150 to send. I can get a quote if you are genuinely interested.
  • 3 weeks later...
These items are still for sale, pics are in first post if required.
Standard ecu $95
  • 3 weeks later...
  • 3 weeks later...
  • 5 weeks later...
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
