So dunno if you guys haven't heard about this and aren't excited, or have heard about it an assumed everyone had also... But there is a new PC coming out from the UK. It's the size of a credit card and was primarily devoloped to be supplied to schools to encourage kids to learn to program. You plug in your mouse, KB, SD card with apps/OS, power (micro-USB), a monitor (HDMI) and you're off. There are some pretty cool possibilities with the Raspberry Pi; From real Pip Boys, to a new range of Carputers, to home media centres (can play full 1080p), to kids actually learning how to program. The Raspberry Pi speaks Python and is going for real low cheap. How Cheap? $25-$35 (there are 2 models thus far - 128 and 256mb). Unfortunately they are sold out at the moment, and their website crashed 2 days ago on launch from the demand. But the world will eventually get a slice of the Pi. May even give me a chance to learn how to use Python...
Check it out!
Their Website
Raspberry Pi Wiki
DISCUSS!:geek:
https://www.sau.com.au/forums/topic/393516-raspberry-pi/
not sure ill put money down today since its only $35 US get a 32gb sd card and there is heaps of songs and stuff for carputer
all we need is a nice plastic case maybe Jaycar or someone in the know would know where to get them made
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6259312
  • 3 weeks later...
did you end up gettign this Madaz?
was thinking of getting it to run in the car as well!
They still havent got emissions certification so no customers have them yet. You might want to wait till the second batch come out though as they will be cased and may have more options (more RAM, I/O etc).
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6301858
any release dates on the second batch ?
I haven't seen any but even if there were some dates available I wouldn't have much faith in them being adhered to. I don't think they have even decided on a design yet. There are plenty of people making their own cases so it might be worth considering. A mate had a mini ITX computer set up inside a remote control car body (Skyline of course). With the smaller footprint of the Raspberry you could do it with a plastic airfix model, or a tupperware box or anything.
Someone designed this Lego case - check here for some other ideas people have had http://www.raspberrypi.org/forum/general-discussion/cases-for-the-raspberry-pi
Edited by *LOACH*
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6304251
Just an update - the PIs are now being received by customers.
There is quite a backlog so if one is ordered today it won't be received until about July.
I think the case design is finalised but you can't actually order it yet.
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6322122
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
