SF-DIS001 is the model number. Not sure where on them exactly, but they should be there somewhere. Easiest way to work out is did your 26 have an igniter pack to run the coils?
If so, then pm me an amount for postage.
Thanks.
UPDATE
1. RB26 VIRGIN ENGINE BLOCK (bare block in good condition) $800
2. R33 GTR RB26 Crankshaft (purchased brand new and used for approx 15,000 km's) $350
3. RB26 RACEPACE FORGED PISTONS 86.5mm (used for 20,000 km's) $400
(slight damage to 1 piston as per photo - engine builder assures that it can be reused or another one can be sourced from racepace)
4. RB26 ADJUSTABLE CAM GEARS (good condition unsure of brand) $200
5. RB26 COMPLETE HEAD (head fully rebuilt less than 20,000 km's ago. Head has been pulled down
and needs to be re-assembled all parts included) $500 SOLD
6. RB26 STOCK INTAKE PLENUM, THROTTLE BODDIES & THIRD SECTION $450 SOLD
7. RB26 POLISHED ENGINE COVERS ALL 4 PIECES SOLD
8. SPLITFIRE COIL PACKS (less than 20,000 km's - good condition) $400 SOLD
9. 700CC DENSO INJECTORS (pushed 400kw without any issues) $450 SOLD
10. GARRET -5 TURBOS (very good conditions done less than 20,000 km's) $2100 SOLD
11. DUMP PIPES - XFORCE WITH 02 SENSORS (good condition) $250 SOLD
12. POWER FC WITH HAND CONTROLLER (good condition a few pixels burn out on hand controller
screen) $700
13. OIL FILTER RELOCATION KIT & CUSTOM RACEPACE OIL COOLER WITH METAL DUCTING $500 (Sold pending payment)
- Speedflow fittings all around, 19 row Setrab unit, 300 PSI rated flame resistant hose made is USA, high quality alloy mounts
14. RACEPACE CUSTOM CATCH CAN ALLOY $200 (Sold pending payment)
15. RB26 R33 GEARBOX (working fine when in car) $500
16. EXEDY TWIN PLATE CLUTCH PUSH TYPE (working fine in car 70% meat left. RRP $2,350) $800
17. R32 GTR SUMP & DIFF $300
18. Z32 AIR FLOW METERS (perfect condition) $350
19. ARC FRONT MOUNT INTERCOOLER $600
20. JJR 40MM ALLOY RADIATOR $150
21. R32 GTR STANDARD AFM'S $150
22. GREDDY RADIATOR NECK $50 SOLD
23. ALCON FRONT BRAKES (complete) $4,300
- Alcon 6 piston 365mm fronts. Braided brake lines.
24. CUSTOM 3.5 INCH EXHAUST (front pipe to tip) $500
25. CUSCO STRUT BRACE $200
26. 18x9.5 BBS LM's $3500 (Sold pending payment)
27. CUSTOM 3 POD HOLDER WITH DEFI BOOST, WATER & OIL TEMP GAUGES - DEFI CONTROLLER $500
28. ARC BLUE OIL CAP $80
29. RB26 STARTER MOTORS X 2 $100 EACH
30. CUSCO AIR DIVERSION PLATE $100
31. R32 GTR RADIATOR SHROUD (broken corner) $70
32. R32 GTR AIRBOX $400
33. R32 GTR QUARTER WINDOW GLASS (BOTH SIDES) $250
34. R32 GTR STEERING WHEEL (poor condition) $70
35. R32 GTR STOCK COMPUTER $250
36. R32 GTR N1 OIL PUMP (good condition) $120
37. R32 GTR POLISHED TURBO CROSSOVER PIPES $200
38. CATCH CAN (A) WITH LINES $200
39. CATCH CAN (B) $150
40. CATCH CAN © $120
41. PISTONS & RODS - RB26? RB30? $50
42. TURBO ELBOWS (A) $100
43. TURBO ELBOWS (B) $100
44. RB26 TIMING BELT COVER (2 of) $50 each
45. RB26 INTERNAL COVER $50 SOLD
46. RB26 CAS $50 SOLD
47. R32 GTR STOCK RADIATOR $50
48. R32 GTR ENGINE FAN $50
49. R32 GTR ENGINE MOUNTS $50 SOLD
50. R32 GTR SANDWICH PLATE $50 SOLD
51. R32 GTR ALTERNATOR $100
52. R32 GTR ENGINE BRACKETS $50 SOLD
53. R32 GTR BALLANCER & PULLEYS $50
54. R32 GTR ASSORTED OIL LINES AND BITS $100 SOLD
55. R32 GTR WATER PUMP $30
56. R32 GTR CLUSTER $100
57. NORGREN PRESSURE REG $100
58. R32 GTR 4WD COMPUTERS/SENSORS $500
59. R32 GTR CLIMATE CONTROL $50
60. R32 GTR KNOBS $50
61. R32 R33 SHORT SHIFTER NEW $180
62. R32 GTR UNDER PLENUM PARTS $50 SOLD
63. R32 GTR CROSS OVER PIPE $100 SOLD
64. R32 GTR MIRROS (3 of - 1 with glass) $50 each
65. ALLOY BATTERY CLAMP SUIT SMALL BATTERY ROATED SIDE ON. $80 (sold pending payment)
MORE PARTS TO COME
CONTACT SAM 0439 702 702
LOCATED IN MELB
Edited by laspy
UPDATE
screen) $700
13. OIL FILTER RELOCATION KIT & CUSTOM RACEPACE OIL COOLER WITH METAL DUCTING $500 SOLD
14. RACEPACE CUSTOM CATCH CAN ALLOY $200 SOLD
26. 18x9.5 BBS LM's $3500 (sold pending payment)
36. R32 GTR N1 OIL PUMP (good condition) $120 SOLD
65. ALLOY BATTERY CLAMP SUIT SMALL BATTERY ROATED SIDE ON. $80 SOLD
MORE PARTS TO COME
LOCATED IN MELB
Edited by laspy
ITEMS LEFT
screen) $700
23. ALCON FRONT BRAKES (complete) $4,300ono
MORE PARTS TO COME
LOCATED IN MELB
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 9 months later...
  • 1 month later...
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
