2nd Owner in Aus
25GT-t Sedan
*****TURBO******
NSW Rego expires end of August
Triptronic Auto
MORE INFO HERE
Viper 2 way alarm with Turbo Timer and Remote Start.
125,000 kms.
Runs Sweet, never missed a beat, been a great car, but family has outgrown.
front & Rear tyres about 6 months old with heaps left.
Never been modified.
Car has Billstein Shocks all round and handles like a dream.
$8,500 ONO
We are not desperate to sell, just would like to upgrade to larger more family oriented cars.
Located Southern NSW.
Cheers Webber
https://www.sau.com.au/forums/topic/393724-forsale-r34-gtt-auto-sedan-mrs-car/
Yes it dosn't sit perfect. if anything the latch probably does need adjusting.
But this car isn't a $10k+ car like the other Turbo ones are.
Car is not "perfect" by any means, but if you want a cheap reliable TURBO 4 door R34 that would clean up cheaply- it is definaltly worth a look. There are a couple of small dings/dints around the body also that didn't show up in the photos. and the blue mark on the front bar (which would rub off). I will have a look and see if i can adjust the boot a little more if you like.
Cheers.
Sorry to hear about your car Blitz-26. Were you insured?
yeah she is fairly gone now.... had a 4x4 sitting in my back seat basically .... yeah i;ll get market value and keep the wreck cause the front and inside and engine etc is in good nick still sad to see it the way it is now.....:closedeyes:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
