  • Replies 117
Posted Images
Plugged in the nistuned z32 ecu today and the car seems to fine with it in, but the exhaust temp light on the dash is on as soon as the car is turned on.
I have a 96 gtst that I always thought was a series 2 which meant I didnt have to worry about the FICD pin on the z32 ecu being different to the s2 rb25det ecu.
Taken from the nistune website:
5) FICD output – pin 33
* Series 1 R33 only
The R33 Series 1 RB25 engine uses pin 33 for the Exhaust Overtemp Lamp on the dash.This line should be disconnected as the Z32 uses this line to drive the FICD (Fast Idle Control Device) – for idle up when aircon is on. FICD is driven seperately on the R33 Series 1 RB25 via the aircon system. Note that the R33 Series 2 RB25 does use the FICD the same as the Z32 ECU, so this modification is not required for those engines
Anyone know what might be causing the exhaust temp lamp to be coming on or If there was some series 1.5 r33's with series 2 bodies etc produced in early 96?
Edited by Mitcho_7
Yeah I been keeping track of your thread.
Sucks man shit never just simply works
Pretty glad I went with the R32 ECU now
Z32 ecu is going back to Matt at nistune today for further analysis/modification.
What's your work situation like this long weekend kasko?
Hotel work man f**ken sucks balls.
Want me to come around on Thursday we can have a look at the profec?
I set mine up and we can just go off my car.
Fuel pump I got DVS to do but there is a walk through on how to do it.
What pump did you buy?
Also do you know anyone with a soldering iron?
I got a nismo in tank so I think it's near identical to the stock setup.
Just had a thought about the profec, im guessing you gotta disconnect the stock boost solenoid, so will it be fine for me to still drive around with the profec b turned off just using wastegate spring pressure to control boost?
Is it even worth trying to install the profec without having the new turbo in?
My dad mau actually have a soldering iron but I'll have to check with him.
What clips/plugs will I need to setup the quick swap over?
I will take a photo of mine and send it to you.
Just go to Jaycar across the road from Wow sight and sound.
Cost me I think $4 a plug and you need 2.
My car already had the stock solenoid removed so was pretty straight forward swap.
I guess maybe leave that till the turbo is done because then you can hook up the actuator etc.
Did you buy a 3 inch intake?
Yeh, I was gonna do that with the turbo seeing as to put in the intake I gotta take out the intercooler pipes in the engine bay to get to it and that will have to be done for the turbo as well
Edited by Mitcho_7
In regards to the plugs for the afm, your stock one had 4 wires didn't it kasko? Which is the same as the z32 plug.
Mine is a series 2 which only has 3 wires (i belive its the same as an r34 afm) from what I can tell I have to put ground and signal ground into the same wire on the stock afm meter loom.
I already have a tomei plug with the 4 wires, so should I just get the exact same plug that's on my stock afm so the wires can be connected up to it and then just clip it to the afm loom?
Anyone with electrical wiring knowledge or someone who has fitted a z32 to their r33 s2 or r34?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
