Just after some info on the VL turbo from people here who have them or have had experience in building them,
1. How much power will the engine and gearbox(manual and Auto) handle before requiring some supports.
2. Will the independant rear suspension ect out of an R33 fit on it?
3. What engine management would suit it best? Apexi power FC? EMS ?
4. TO4 turbo currently installed, how much boost pressure is this turbo good for?
Also any additional comments would be greatly appreciated.. :(
https://www.sau.com.au/forums/topic/39423-vl-turbo-people/
VL turbo people. OK... Just after some info on the VL turbo. It could be a Nissan turbo :confused:
https://www.sau.com.au/forums/topic/39423-vl-turbo-people/#findComment-800931
I had a VL Turbo, as did some of my friends. One of them ran an 11.97 on a standard engine with bolt ons and standard computer. I dont think a aftermarket computer is totally necessary with these cars unless u want to go super fast. Mine put out around the 250rwkw mark and would have been capable of more if i installed an aftermarket computer. Now that they are getting on in age, a rebuild is probably wise as the engines are getting a little tired. I gave mine a freshen up with a complete engine rebuild (top&bottom end) and used ACL pistons and it ran 18psi all day everyday and was a daily driver.
The manual MX7 gearboxes are extremely tough provided they are maintained properly, i never had any problems with mine and nor did my friends who ran constantly at heathcote/calder park with a lot of horsepower running through them. Automatics... if left standard they wouldnt cope with a lot of power... my friends standard vl turbo running 12psi with a supra cooler, the auto box held up for about 6 months with a bit of abuse... on the other hand you could go a trimatic or a jatco 4 speed, in my experience the trimatics held up a lot better. It depends whether you want fast times or not (obviously automatics will provide you with better times). Some people replaced the manual MX7 gearboxes with supra gearboxes, i didnt think too much of this as they kept breaking these boxes, i'd look into the ability to fit an RB25DET gearbox.
Concerning turbos, once again i think this will depend on whether you go manual or automatic... if you go automatic and have a decent stall converter in it, a t04 will be ok... I had a T3/T4 hybrid turbo on it and it was great (built by ATP) as lag is a big concern for me. I have been in near standard vl turbos that have T04s in them (a bt1 with a cooler and manual) and it only made decent boost at 4000rpm, and then having to shift at 6000rpm, so you have 2000rpm of decent power and when you change gears you were out of boost, so it was an absolute pig.
Make sure you have the correct turbo combination on your car, bigger is not necessarily always better, useable power is the key.
Common modifications on a VL Turbo to get yourself into the low 12s high 11s mark:
Fuel Pump
t3/t4 hybrid turbo
3" exhaust from turbo back
intercooler
decent clutch (heavy duty or button)
you can keep the standard 3:4.5 gear ratios in the diff, but 3.9s or 4.11 will definitely help.
cold air intake (the standard airbox works well, just cut a hole in the bottom of it and feed the cold air intake into this)
extra injector or bigger injectors
Cam
Catch can
Thats all i can think of for now... these arent massive modifications, and all the times that my friends ran were on slicks and using aviation fuel and soft springs in the rear end. a T04 depending on the type and the condition its in can run a fair amount of boost, it just depends on your engine - what condition is your engine in and can it handle large amounts of boost.
Hope this helps some what.... =)
https://www.sau.com.au/forums/topic/39423-vl-turbo-people/#findComment-800981
Umm as far as i know VL Turbo boxes are the same strength as RB25DET boxes, or even GTR boxes in RWD form.
taken from www.datrats.com.au "VL TURBO RS5F30A BOX (FITS RB25DET RB30ET AND RD 26DETT ENGINES. THIS BOX IS THE SAME AS THE GTR BOX BUT WITHOUT TRANSFER FOR 4 WHEEL DRIVE. $1500 "
https://www.sau.com.au/forums/topic/39423-vl-turbo-people/#findComment-801092
I believe the VL turbo engine is a RB20det engine.
Not quite mate, rb30et
As for how much they go for, depends what your chasing, could probably pick one up in average condition for around 4.5 -5k, for an sl or exec, as you go up in class, calais in particular your looking at around 6-7 for turbo's in average condition.
good condition they'll go for 10..
good condition with lots of "quality" mods they'll go from anything between 10-20k.
https://www.sau.com.au/forums/topic/39423-vl-turbo-people/#findComment-801530
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
