1: enkei rp01 17 x 9 +22
just had them resprayed silver (matched to the original colour). There was some pitting you can see through the paint that they didn't fill in. They look nice from a couple of metres away.
$900 + $50 postage Australia wide.
enkei rims
2: Garret turbos for a GTR. 2860 -7 I believe.
Just rebuilt by Precision Turbos. Both have brand new bearings and the exhaust housings have been ceramic coated in black. As good as new.
Part numbers from the cores:
HH 0110J
14411-AA403
707160-7
Part number from actuators:
430819-369
08223
35367
$1600 + $50 postage (includes insurance)
turbos
3: R32 GTR Fibreglass front diffuser
The one in the link is the one I bought
R32 GTR diffuser
$220 + $25 postage
4: Speedline 17 x 9 +25
Tyres are dead but may pass rego. I lost one centre cap on the road :( Comes with the centre cap tool too. :)
usual small gutter rash
$400 + $50 postage
speedline
5: 4" stainless exhaust
Front pipes to back
only used for a short time by previous owner, catco cats on each leg of the front pipe. Will need to be welded back together. I cut it up to squeeze it in my car.
$400 can be posted but unsure of postage costs.
exhaust
6: r32 GTR side skirts 2 pairs
both need straightening and one set needs painting, the other needs a GOOD polish
just take them.
7: RB26 block with rods pistons and crank (pistons and rods removed from block)
no cracks, all is in good nick.
$200
8: R32 GTR Tomei dumps, the older fabricated ones BRAND NEW AND UNUSED
ceramic coated black, will accept only the R32 GTR 02 sensors. provisions for exhaust temp sensors on both pipes
$600 + $15 postage
tomei dumps
9: used aftermarket rb26 manifolds not sure on brand, no cracks, provisions for heat shields
$200 + $20 postage
manifolds
10: used rb26 heat shields ceramic coated
$80 + $15 postage
heat shields
11: R33 GTR aircon compressor sold as is
$50
air con compressor
12: R33 GTR standard clutch, flywheel and pressure plate USED
$50
clutch
13: N1 water pump used
$50 + $12 postage
14: N1 oil pump used, not cracked
$50 + $12 postage
15: ex BSM R32 GTR sump, with baffles and extended pan
needs a donor sump for the diff parts
$850 + postage
sump
16: standard r32 gtr sump good condition
$200
17: ex BSM R32 GTR Quaife front diff centre used but in good condition
$1200
quaife
18: tomei pon cam replicas bought from dirtgarage (who used them for a short time) then not used by me.
260in 260ex 9.15mm lift
$400 + $20 postage
19: R32 GTR fibreglass N1 bonnet lip painted in white NEW
$80
lip
20: R32 GTR fibreglass N1 boot lip painted in white NEW
$160
lip
21: R32 GTR Trust style fibreglass rear pods painted in white NEW
$160
pods
Will post at buyers expense. Pick up is available from Quakers Hill.
Cheers
Josh
https://www.sau.com.au/forums/topic/394428-skyline-parts/
enkei rims
HH 0110J
14411-AA403
707160-7
430819-369
08223
35367
turbos
R32 GTR diffuser
$220 + $25 postage
$400 + $50 postage
speedline
6: r32 GTR side skirts 1 pair
just take them.
7: RB26 standard rods pistons in excellent condition
$100
$200 + $20 postage
manifolds
$50
air con compressor
$50
clutch
$50 + $12 postage
$850 + postage
sump
$200
$400 + $20 postage
$80
lip
$160
lip
$160
pods
Cheers
Josh
Items updated
https://www.sau.com.au/forums/topic/394428-skyline-parts/#findComment-6303499
  • 3 weeks later...
enkei rims
HH 0110J
14411-AA403
707160-7
430819-369
08223
35367
turbos
R32 GTR diffuser
$220 + $25 postage
$100
$200 + $20 postage
manifolds
$50
air con compressor
$50
clutch
$50 + $12 postage
$850 + postage
sump
$200
$400 + $20 postage
$80
lip
$160
lip
$160
pods
Cheers
Josh
https://www.sau.com.au/forums/topic/394428-skyline-parts/#findComment-6344103
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
