  • Replies 192
  • 6 months later...
I used to be firmly in the 34GTR camp and do hope to own one in the near fut..who am i kidding, in about twenty years at the way i go through beer coupons but i have slowly come around to the killerwhale look of the 33GTR, examples above and below surely cant be ignored?
Yeah I agree...I was going to upgrade to a R34 GTR but since owning a R33 GTR and spending so much caash on it....I have grown to appreciate it much more and think with the right wheels and clean look - the R33 has the toughest stance!!
