Go with what you have then...gotta keep the teacher happy ;)
Duncan
the extract, for educational purposes only (copyright) is from Race Car Engineering and Mechanics - Paul Van Valkenberg, HP books and is available from http://www.bevenyoung.com.au/prdt393.htm
I can put a bit more res in, but it will be larger. Give me a couple of hours as the other half is wanting me to do a couple of things.
Great post skylinegeoff. Im currently studying 3rd year mech eng and am also interested in getting into race engineering. How did you go about finding more info about getting into the field? Also, can you recommend any other books etc that are worthwhile to read on the topic?
repost of images. the rest of the article is very race specific so I have left it out. Seriously recommend buying this text due to the broad nature. Also just good reading.
Rhett
try a search and look through that website I posted for the book. Also look at a mag called Racecar Engineer.
In melb there is Kangan Batman TAFE that runs a tech course in race mechanics as well as race engine building...worth a look. Some of the uni's have automotive engineering undergrad degrees but couldn't help me with a masters in race engineering or any of the other areas I am interested in such as automotive management.
Searching online you will find a fair amount of info as well. There is also a member on the forum who is highly experienced in race car dynamics and engineering, as well as managing a team (if it still operates after PROCAR closed down) but I won't post his details to prevent him getting bombed with questions. He already does enough and if you are truly interested you will be able to deduce his identity, or he will announce it himself, probably as he adds a mountain of relevant info to this thread.
Majanal : You wrote somewhere that you have a few suspension goodies... From a non scientific perspective, what sort of difference did good suspension make to your drifting? What difference did the locker make?
Ok, sorry about the slow reply.
I found that the suspension made the car behave in a much more controlable way, I was able to predict what it was going to do, which was sometimes "oops" lol. Made the whole car much nicer to drive and by the end of the day I was pretty much able to link the whole track.
The locker helped also as when I flawed it on the flick back it would spin both wheels instead of just the one and therefore give again more control, sounds backwards I know, but when you have one wheel spinning and one gripping it really sucks, as you have to drag that tyre around with you.
Hope that helps, if not, please feel free to ask specific questions and I'll do my best to answer!
Dan.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
