S A U N S W - Texi, "the Original" @ Sutton Road
-2 is balmy.
some ppl got air, but you have to really push it. most of the time its just the suspension droop, and most of the time your survival instincts kick in and make you slow down for it...
how powerful is your car? you probably won’t get to 4th.
  • Replies 219
They used to do (still might, not sure) a quarterly event there on the skidpan, as far as I'm aware it was never the track though.
yep as I posted earlier (I think) they are running a Motorkhana on the vehicle manouvering (sp?) area on the Sunday. Pretty sure there wont be any more spots for that, they had 10 left a week ago. I'll be doing both :)
Oh and picked these up today, will be giving them a run on Saturday :D
A few questions after watching that video linked from page 1 for the 200th time:
  • does that bloke get air over the crest at one point in the first half of the course?
  • is the course going to be set up exactly like it is in the video?
I'm keen to know if we are going to see enough straight road to get into 4th gear at serious speeds.
Forecast for Saturday is looking good! -2 over night...shiver me timbers!
No air but car gets light depending on your approach speed. It's up to you how fast or slow you approach it.
No cones will not be exactly the same places as that video
4th won't happen on the straight unless you have mega power
i have mega power so hoping to hit 4th everytime round.
also going home hat in hand if i dont get air!
matt, there is a cruise thread for the drive down, i wont be able to head off till 4 from balmain thanks to gf's lame work.
Lol, well, here's one person going for times haha :D
Great stuff mate!!
Scott, don't worry so much! You'll live longer :D
There is a slow lap at the start where everyone goes in single file at a slow pace so you will be familiar with the track.
By mega power, I'm talking 420rwkw and upwards. I'd expect you to be in 2nd or 3rd for the whole run (of course with the exception of 1st at 7500rpm for the launch at the start)
Also that crest is like any crest you see in hilly parts of Sydney, for example the big one in Greenwich. You're not encouraged to go flat out over it and by doing so your time will be slower anyway so stuff that. If it's really bothering you I'll take you to it in the morning before runs start and drive over it myself with you in the car to demonstrate it's perfectly harmless when common sense is used :)
Hey,
I'm keen, can't believe i only just found out about this.
Are there any spaces left?
and is there any extra cost to get the appropriate cams license on the day?
Hey,
Yes spaces left. Send the form and money today and you'll be fine.
There is no extra cost for the CAMS license other than the actual cost of the license (eg it costs you no more to do it on the day, but the license cost still has to be paid)
Hey guys,
Any chance of entering on the day? Only just remembered about it now. I've already got CAMS etc
Thanks
We prefer to not do entries on the day as it's pretty crazy for the volunteers in the mornings, and we are short a few volunteers for this, but if that's the only way you can do it.....
I'll help where possible, just pint and tell me, do such and such over there....
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
