Hi guys
i just put a Neo in My R33 GTST S1
my mate think the r33 S1 ecu will not work
need info on how to wire R34 coilpacks to R33 S1 loom
and looking for anyone on what i should do or look out for
and what ways should i go with loom and ecu
i got told you can bolt all r33 stuff to the Neo motor and use r33 loom
any info will be good thanks
TAHNKS
https://www.sau.com.au/forums/topic/395631-puttng-neo-in-my-r33-s1/
Dude do yourself a favor and buy a R34 RB25det neo ECU+loom.
Why root around buying series 1 and 2 RB25det parts for your NEO engine? Neo loom and ecu is a direct plug and play with minor modification.
Dude do yourself a favor and buy a R34 RB25det neo ECU+loom.<br><br>Why root around buying series 1 and 2 RB25det parts for your NEO engine? Neo loom and ecu is a direct plug and play with minor modification.<br>
its a direct plug and play into the engine yes but not the car, you would have to wire the neo loom to the car, not difficult if you know what your doing.
but you have a point.. it will give a better result. you can then use the nistune on the 34 ecu also
R34 loom as to be wired in to your dash loom
so many people have done NEO swaps and still use there own Loom
need more info guys...will R33 S1 power NEO motor ? and will RB20 nisstune power a NEO ? and putting in R34 loom and ECU in R33 S1 gtst what will be need to be done to make all of it work ? need as much info guys plz thanks
S1 loom uses a separate ignitor this wont work with the neo coils and you wont be able to fit s1 coilpacks in there. So the EASIEST way to make it all work would be to run a Series 2 RB25 loom, it will plug into your 33 no worries, gets rid of the ignitor and then you can run neo coil packs. The RB20 ecu will run it no worries.
Adapting the neo loom and running the neo ecu with a nistune would give a better overall result but at the expense of more work since theres a fair bit of rewiring to make the neo loom fit your r33.
yes you can still use all those things HOWEVER making the abs work will be very time consuming.
just get a s2 R33 loom
i have the s2 coilpack plug to go to the ecu loom so cant i use the r33 s1 loom and wire that s2 plug on there ?
  • 11 years later...
He was last active nearly 10 years ago. Thread necro no likely worky worky.
The best advice is clear out all the old crap, use an aftermarket ECU, build a complete new loom from scratch.
The next best advice is use an R34 engine loom & ECU, adapt it where necessary to mate to the R33 body loom. Then at least you have a Nistunable ECU.
The worst idea is to keep any of the R33 stuff.
  • Haha 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
