Well just thought id update with a picture of the freshly painted block. I also cleaned the remaining head gasket off the top after this pic was taken. Pretty much now ready for assembly :)
So long time no update. Well not much has changed. Still waiting on the head to come back. and for my tax to come in so i can get the turbo set up and cams ect paid for. Picked up an EBoost2 for the boost control and also salvaged my old AF ratio meter from my blue 33. Mounted the custom sheet metal console and also made up a plate where the center vents go for the 2 gauges. will be putting more gauges under the switches ect later on. Please note im an amateur metal worker and am nowhere near a pro lol. But atm its more for practical then later on ill re do all the metal work, which wont be much lol. Heres a few more pics.
So got the 25 gearbox out today. Ready to go into the 32. Got a call from the head shop. Exhaust valve guides were a little dodgy so got them replaced. Valves shaved and seats smoothed. Was expecting it back today but they were a no show. Standard cams will be put in for now until the ones from the states arive. Getting closer :)
Man, im loving this thread, im building exactly the same car, with the same emphasis, and my car happens to be the same colour!
Mine in currently standard, RB20, with a FMIC, and CAI, just bought a cheap LINK ecu for it, and found some used TEIN adjustable suspension for dirt cheap, and doing the HICAS removal kit on monday. i cant wait to see and hear more about your toy. Keep us informed - if oyu want more info Message me.
  • 4 weeks later...
Just an update guys, motor is 3/4 back together on the stand. Just chasing a forward facing plenum, a turbo and the water line that wraps around the back of the head. Shes been put together with just standard cams for now, once motor is run in and i have more $$$ i will upgrade to the tomei items. Pics will be up shortly of the build process of the motor.
what turbo you chasing?
what made you decide to go tomei cams, from what i have read its not that much of an upgrade, not flaming just curious to know.
still loving the thread cos its sick to see some 32 love.
Tomei just seen alot of people using them, i did get quoted other brands that were local ones but they were same price if not more expensive. I herd they are good but only if you are combining them with a nice turbo upgrade, ecu injectors ect. They were only going to be the PON CAM which doesnt require the replacement of the valve springs ect. The turbo im chasing is probably i hi flowed series 1 R33 turbo, i actually have a stock S1 R33 turbo in my posession but am unsure of its state of repair. Looks ok but never saw it running on the engine i took it off. Then later on probably a 25/30 or something like that.
Turbo choice is very critical on the little 20 , what sort of power are you chasing? , if you're not sure what power you want then do as much research as you can before spending any more hard earned! The forced induction forum is a good place to start , there's plenty of info in there about turbo and other bolt on bits that can save you thousands by learning from other peoples mistakes :) . Just saying ;)
(2 threads that would be a good start are the kando and hypergear threads , they are mostly for rb25 but a keen reader will find the stuff on rb20 )
Thanks mate, Yah ive just put a S1 33 turbo on for now, just until i can get the motor up and running to sort little gremlins out. Was looking at a 25/30 or equivelent obviously ball bearing and not ceramic. Car will be used mainly for texi and track days, but rarely for drift. So ceramic for now running 10psi hopefully will hold for a little.
Ordered the forward facing plenum which sits on top of the standard runners. Then motor can be dropped in. Have re ran coolant lines to delete where the heater hoses used to go to the core. sorted the oil light switch and mounted the short wiring harnes on that side. Unsure wether to run cooling lines to the trottle body still. Am using the standard 65mm Rb20 throttle body so does have the connections for the cooling lines. If not will just loop the 2 ports. So now i play the waiting game, expecting the new shinny chrome manifold to arrive tuesday or wednesday. Getting closer :)
Plazmaman is the only brand I'm aware of that just does the plenum section of the intake manifold; did you get a copy or genuine? Or is there another company making a similar product?
Check EBay mate, found them the other day.... Similar to Plazmaman but a bit squarish... Was going to send Alex the link but forgot...
Yeh I've seen the copies, they've been out for probably around a year or so now. That's why I asked, I'm interested to see how they go compared to the genuine versions.
Edited by Hanaldo
Yah its an aussie company Vulture motorsports. They are in the buisnes section of the sale threads. Its a copy and about a 1/4 of the price. Being that this is a track car im not concerned if it causes a problem later on cause it wont matter if its off the road lol.But ive asked around and this is the only option for the little 20 unless as you say a plazmaman one which im not forking out over $1000 for just a track pig lol. I will definately have dyno sheets up and let you know how it feels on track once shes all up and going :) TBH i just want to hear her run with the side pipe exhaust im putting on her ;)
So I have bit the bullet and brought the forward facing manifold new from vulture motorsport. Nowhere near a straight fit. After trimming every bolt to mount the manifold top i finnally got it on, and brought all the extra fittings. Installed the short drivers side harnes to the block and mounted throttle body along with replacing all coolant lines. Installed the turbo lines behind the head and now motor is ready to put in hopefully tomorrow. Also sourced a RB20 gearbox crossmember to suit the 25 box. So that is also ready for install. Still finding options for the tailshaft which is my last major hurdle. Heres some more pics :)
So the best update so far. MOTOR IS IN!!!!! :) Got the motor in here yesterday. Today i have installed the wiring harness, along with extending the plugs for the TPS and Idle speed control. Also ran the boost line for the Eboost to the manifold. Also looked at a cusion button clutch which i shall be getting next week. Being only aprox 150-200kw nothing major is required...yet. So once i have that 25 box will be going in and hopefully all down hill from there ;) Here is a nice pic. :)
So been doing little loose ends today, works been a bit slow so why stand around when theres a 32 to be built. So ran new soft fuel lines in the engine bay, finnished the main engine loom including plugging the ECU in ect inside the cabin. Replaced fuel filter and also hooked up the cool looking SARD fuel pressure reg. I know shes not a 500hp weapon but being a track car always nice to be able to pop the hood and check how your fuel pump is holding up. Especially when and if you run into dramas under load. Just need to get now some silicon boost line for the wastegate, boost control and BOV lines. Also some pipe for intercooler and idle air control vac lines. Getting closer :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
