hey guys have the following parts for sale :
- r33 series 2 side skirts $150 for pair
- r33 series 2 rear pods $ 70
- r33 series 2 genuine nissan floor mats $70
- r33 gauge holder with gauge , replaces front ash tray - fibre glass $20
- r33 series 2 boot with duck lip spoiler ( boot has some holes which some ideot tried attatching a drift wing :( ) take the lot , wont be removing spoiler $100
- r33 series 2 front bumper , with m spec front lip ( lip has 2 cracks in it , nothing that cant be repaired by body shop ) $140
all parts pickup from sydney , pm me for details. everything is in good condition.
https://www.sau.com.au/forums/topic/395776-r33-series-2-parts/
update :
- front bumber SOLD
- floor mats SOLD
- drift wing pending payment/pick up from wilderboy .
- gauge holder sold pending payment
skirts and rear pods still for sale.all must go
  • 2 months later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
