Selling 2x R34 GTT standard wheels in gunmetallic colour.
One wheel has gutter rash, other one is good condition.
Please refer to pictures. Pick up preferred @ Bankstown NSW.
Please call 0410 576 133. If i am unable to answer, please leave txt and i will get back to you.
http://www.gumtree.com.au/s-ad/bankstown/wheels-tyres-rims/r34-gtt-wheels-x2-100-/1000506032
https://www.sau.com.au/forums/topic/396003-r34-gtt-wheels-x2-100/
Interested in the one without gutter rash to replace one of my current ones that has gutter rash :happy:
are you suggesting that you are interested in only buying one wheel, out of a $80 pair?
you may possibly be the biggest tight ass on this site
  • 4 weeks later...
