  • Replies 57
Posted Images
Updated list
· 3 Inch Bellmouth Front/Dump Pipe, stainless steel not some crappy ebay thing some scrapes on bottom (cost me $1000, used 10000km at the most): $400 only bellmouth front/dump
· Apexi Power FC for RB20DET: $1000
· RB20DET with exedy heavy duty clutch and starter motor (as well as AC motor i think) still on NO TURBO, INJECTORS or COILS $200
· 550cc Tomei injectors $600 ON HOLD
· Highflowed r33 turbo (a little noisy bearing but the guys at Pulse Racing told me after intall that it was ok, always ran well) $400
· 260km Nismo Cluster for GTST with LEDs in it: $200
· Foglights: $60
· GTST rear door trim: $30
· GTST Front Seats: $100
Couple of small marks and a small indent (maybe burn) in driver'sseat.
· Floor Mats hole where the hook goes into onthe drivers mat and stain on passengers front: $50
· Left and Right Doors these have everything still on them… trim, mirrors, glass: $150 each
Small marks, and slight scrapes on back of the mirrors but generally really good condition.
· Door Seals: $20
· Door Panels (with skyline written on them): $20
· Rear Bumper some faded paint but good condition: $100
· Rear Reo Bar: $50
· Front Left and Right Kick Panels (I think that's what they are): $20
· Boot Lid A tiny bit rust around one of the holes: $50
· Climate Control: $40
· Climate Control/din/gear stick main piece not facia: $10
· Stock Cluster: $70
· Left and Right Tail Light Globes: $15
· Greddy Turbo Timer: $50
· Interior Carpet great condition: $60
· Aircon Box: $40
· Heater Box With Heater Core: $80
· Plastic Beneath Windscreen: $10
· Stock Front, Dump Pipe and Cat: $60 each for front and dump pipe, $20 for cat, all 3 for $110
· R32 GTST Wing - Faint scratch but good condition: $40
· Windscreen Water Bottle: $20
· Coolant Reservoir: $20
· Stock ECU: $80
· Boost Tee: $50
· Stock Injectors: $50
· 2 Reservoirs I think fuel and power steering (see pics): $20 each
hey mate im interested in the speaker grills on the door panels if you want to separate. the small surround that holds the gear stick boot up also if you have it the rear pillar panel. my clips are broken and the panel is screwed
  • 4 weeks later...
  • 3 weeks later...
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
