well i'm not a mechanic, nor have i pulled down a RB before, but i have taken off the cover for the timing belt, and they almost look like the locators for the backing plate behind the timing belt to attach to the block, but like i said, i wouldn't know for sure
The head is sitting square and in the right position I removed a couple of head studs to check, but I won't take the risk of it shifting under heavy load its been 4 years since i drove my gtr and god i miss it, ive just been down to gm Motorsport in melton and bought my self a 1.69oz tube of arp assembly lube enough to build the motor 20 times! So off to the workshop for another tear down
Cheers cam
They are definately the head to block dowels, I installed mine just the other day and they were the same (with the split). I also used ARP studs with them. I would definately take the head back off and install them.
The motor is still on the engine stand, I prob used the stud kit as alignment and not thought twice, the r33 engine manual has no mention of there being locating dowels which is why I may have over looked it, guess what I'm doing this weekend then god damn it!!, unless you guys think the arp stud kit would line the head up enough?or best not to risk it?
  • 2 months later...
After 4 years of slowly gathering parts for my rb26 im finally putting her back together(spun bearings) 4 years is a long time and cannot remember for the life of me where the hell these go!!they where in the same zip lock bag the 3 bolts for the lower front cover was in but cant see them being used for the front cover, hope some one can reconize these 2 sleeves i guess you would call them? and save me having to pull the motor apart again!
Did you work out where they go?
I had lower front cover off... also the entire intake side and water pump. Have ti all back together and have these two suckers left over! Would rather not have to do it again.....
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
