Set of 4 Volk racing wheels. Clears the brakes on R32 and R33 GTST skylines - however will require spacers for an R34. Great used condition with minor gutter rash as pictured - nothing that effects the wheels performance in any way.
The tyres are Yokohama Advan AD06's. They all still have a lot of life left in them - two of them are nearly brand new (They retail for around $500 a pop).
The wheels would be good enough to use everyday if you wanted to - I was just using them for the track.
$700 - the rubber is worth way more than that.
ALSO
Pair of Japanese wheels with 40% rubber - would suit skids or budget concious rim seekers (buy two pairs).
Clear the brakes on Skylines on the rear (half a staggered set).
17 X 9.5 with 5x 114.3 studs and 225 rubber.
Good used condition.
Oh and I've also got one of those Phillips HID Conversion kit complete 4200K of raw lighting power. I'll take $200 for it.
Give me a call on zero four 18666332.
I should probably have mentioned....
The Volks are +35's and 8 and 9 inches, the rubber is 235's.
The pair are also +35's :)
  • 1 month later...
