Like Boostmeister says - use the layer mask.
Also use a soft brush. If the OEM ones aren't soft enough, you can 'tweak' them by using the side option menu from the brush-size dropdown (in PS 7)
Jamezilla, good point.
Hiroshima Screamer, if you have problems, send me the pics and I will do it for you [email protected]
PVA, you can do in in PS but its not just a insert and done type of program unlike the software that comes with cannon digi cams "Photostich".
Here's an example of photo joining in PS.
This is what 3 seperate photo's look like when joined, there was actually a fair bit of work in doing this. For those who don't know where it was taken....This is the view from 10 meters out in the water at 6am on a Sunday morning at Surfers Paradise. You have about ten minutes to take the shots you want before it gets too bright.
Black and white is easy to do but there is B&W and there is B&W, I personally like "Black" not grey so you have to tweak the pic a bit. This is done in curves to a good effect.
First though just open a colour bit the go image>mode>greyscale to change it to black and white, just remember that you will not have all effect options available to you to use so mod the pic first THEN GO B&W
Just did it quickly, it all comes down to the images you start with. Make sure they are high res and try and take as many as possible, this is not always the case, it will depend on your camera.
Some cameras expose the shot well while others can make the sky totally different colours, this is when it is hard to blend....sometime I have to almost totally recreate the entire sky
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
